ASUS X550LB-DS71 Display Panel Replacement
  1. ASUS X550LB-DS71 Display Panel Replacement, Display Panel: step 1, image 1 of 3 ASUS X550LB-DS71 Display Panel Replacement, Display Panel: step 1, image 2 of 3 ASUS X550LB-DS71 Display Panel Replacement, Display Panel: step 1, image 3 of 3
    • Flip open the laptop with the screen facing towards you.
    • Using the plastic opening tool, remove the square tape from the marked locations.
    • Use the Phillips #0 Screwdriver to remove the two 2mm screws from those locations.
  2. ASUS X550LB-DS71 Display Panel Replacement: step 2, image 1 of 2 ASUS X550LB-DS71 Display Panel Replacement: step 2, image 2 of 2
    • Using the plastic opening tool, open the front cover of the laptop.
    • It is recommended that you start from a corner and run the tool along the edge of the cover.
    • Be careful not to bend or crack the cover.
  3. ASUS X550LB-DS71 Display Panel Replacement: step 3, image 1 of 3 ASUS X550LB-DS71 Display Panel Replacement: step 3, image 2 of 3 ASUS X550LB-DS71 Display Panel Replacement: step 3, image 3 of 3
    • Peel off the tape located on the left and right side of the display monitor.
    • Use the Phillips #0 screwdriver to remove the screws at the marked locations in each corner of the display.
  4. ASUS X550LB-DS71 Display Panel Replacement: step 4, image 1 of 3 ASUS X550LB-DS71 Display Panel Replacement: step 4, image 2 of 3 ASUS X550LB-DS71 Display Panel Replacement: step 4, image 3 of 3
    • Place the display monitor face down to expose the ribbon connector.
    • Remove the ribbon connector to separate the display monitor from the rest of the device.
Nathan Dyer
550 Reputation
5 Guides authored
USF Tampa, Team S16-G1, Eyestone Fall 2017 Member of USF Tampa, Team S16-G1, Eyestone Fall 2017
USFT-EYESTONE-F17S16G1
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 17
All Time: 1,047
