ASUS X550LB-DS71 Optical Drive Replacement
  1. ASUS X550LB-DS71 Optical Drive Replacement, Optical Drive: step 1, image 1 of 3 ASUS X550LB-DS71 Optical Drive Replacement, Optical Drive: step 1, image 2 of 3 ASUS X550LB-DS71 Optical Drive Replacement, Optical Drive: step 1, image 3 of 3
    • Make sure to switch off your laptop before starting.
    • Place the laptop on a flat surface with the bottom side facing upwards.
    • Using the Phillips #1 Screwdriver, remove the four 4mm screws in the back panel.
    • Using both hands, slide the back panel away from the laptop horizontally.
  2. ASUS X550LB-DS71 Optical Drive Replacement: step 2, image 1 of 1
    • Using the Phillips #0 Screwdriver, remove the ten 2mm screws at the marked locations.
  3. ASUS X550LB-DS71 Optical Drive Replacement: step 3, image 1 of 3 ASUS X550LB-DS71 Optical Drive Replacement: step 3, image 2 of 3 ASUS X550LB-DS71 Optical Drive Replacement: step 3, image 3 of 3
    • Using the plastic opening tool, open the back cover of the laptop.
    • It is recommended that you start from a corner and run the tool along the edge of the cover.
    • Be careful not to bend or crack the cover.
  4. ASUS X550LB-DS71 Optical Drive Replacement: step 4, image 1 of 2 ASUS X550LB-DS71 Optical Drive Replacement: step 4, image 2 of 2
    • Using the Phillips #0 Screwdriver, remove the 2mm screw at the marked location.
    • Remove the Optical Drive by sliding it to the right.
Nathan Dyer
550 Reputation
5 Guides authored
USF Tampa, Team S16-G1, Eyestone Fall 2017 Member of USF Tampa, Team S16-G1, Eyestone Fall 2017
USFT-EYESTONE-F17S16G1
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 21
All Time: 2,009
