ASUS X550LB-DS71 RAM Replacement
  1. ASUS X550LB-DS71 RAM Replacement, RAM: step 1, image 1 of 3 ASUS X550LB-DS71 RAM Replacement, RAM: step 1, image 2 of 3 ASUS X550LB-DS71 RAM Replacement, RAM: step 1, image 3 of 3
    • Make sure to switch off your laptop before starting.
    • Place the laptop on a flat surface with the bottom side facing upwards.
    • Using the Phillips #1 screwdriver, remove the two 4mm screws in the back panel.
    • Using both hands, slide the back panel away from the laptop.
  2. ASUS X550LB-DS71 RAM Replacement: step 2, image 1 of 2 ASUS X550LB-DS71 RAM Replacement: step 2, image 2 of 2
    • Using your thumbs, push the two metal tabs (one on each side) outward until the RAM card pops out.
    • Take the RAM out.
    • To put the RAM back in, push the RAM down until it clicks in place.
2 other people completed this guide.
Nathan Dyer
550 Reputation
5 Guides authored
USF Tampa, Team S16-G1, Eyestone Fall 2017 Member of USF Tampa, Team S16-G1, Eyestone Fall 2017
USFT-EYESTONE-F17S16G1
4 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 10
All Time: 1,248
