ASUS X552LAV-BBI5N08 Hard Drive Replacement
  1. ASUS X552LAV-BBI5N08 Hard Drive Replacement, Battery: step 1, image 1 of 1
    • Battery is not showed in pictures.
    • Flip the laptop face down.
  2. ASUS X552LAV-BBI5N08 Hard Drive Replacement: step 2, image 1 of 3 ASUS X552LAV-BBI5N08 Hard Drive Replacement: step 2, image 2 of 3 ASUS X552LAV-BBI5N08 Hard Drive Replacement: step 2, image 3 of 3
    • Slide the right button to the left.
    • Hold the left button to the right.
    • While you hold the left button in position, slide the battery out by pushing it away from you.
  3. ASUS X552LAV-BBI5N08 Hard Drive Replacement, Hard Drive: step 3, image 1 of 1
    • Start by flipping the laptop face down.
    • Locate the bottom panel. It is at the opposite end of the battery.
    • Remove the two 12mm screws at the bottom panel with a Tri-wing Y1 screwdriver.
  4. ASUS X552LAV-BBI5N08 Hard Drive Replacement: step 4, image 1 of 3 ASUS X552LAV-BBI5N08 Hard Drive Replacement: step 4, image 2 of 3 ASUS X552LAV-BBI5N08 Hard Drive Replacement: step 4, image 3 of 3
    • Remove bottom panel by lifting it up.
    • Locate the hard drive.
    • It is located in the bottom left corner.
  5. ASUS X552LAV-BBI5N08 Hard Drive Replacement: step 5, image 1 of 3 ASUS X552LAV-BBI5N08 Hard Drive Replacement: step 5, image 2 of 3 ASUS X552LAV-BBI5N08 Hard Drive Replacement: step 5, image 3 of 3
    • Remove the four 5.5mm screws located on the hard drive case using a Tri-wing Y1 screwdriver.
    • Slide the hard drive out to the left.
  6. ASUS X552LAV-BBI5N08 Hard Drive Replacement: step 6, image 1 of 2 ASUS X552LAV-BBI5N08 Hard Drive Replacement: step 6, image 2 of 2
    • Lift the hard drive out.
    • Once the hard drive is removed, place the hard drive at a different area.
  7. ASUS X552LAV-BBI5N08 Hard Drive Replacement: step 7, image 1 of 3 ASUS X552LAV-BBI5N08 Hard Drive Replacement: step 7, image 2 of 3 ASUS X552LAV-BBI5N08 Hard Drive Replacement: step 7, image 3 of 3
    • Place the hard drive on its side.
    • Remove the four 5mm screws from the sides of the case by using a Tri-wing Y1 screwdriver.
    • Lift the hard drive out of the case.
Jason Vo
857 Reputation
5 Guides authored
USF Tampa, Team S17-G1, Boczar Spring 2018 Member of USF Tampa, Team S17-G1, Boczar Spring 2018
USFT-BOCZAR-S18S17G1
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 311
