Introduction
This guide will show you how to replace the screen on a ASUS X552LAV-BBI5N08 laptop.
Remove the six 12mm screws located at both the battery area and the bottom panel, with a Tri-wing Y1 screwdriver.
Slide the bottom panel down and lift it up to remove.
Remove the seven 5.5mm screws located at the bottom area with a Tri-wing Y1 screwdriver.
Flip laptop to sit with the screen on the bottom.
Use tweezers to remove the square decorative sticker from the top of screws from the edge of the screen frame.
Remove six 4mm screws (with a JIS #1 screwdriver) from under the stickers and both of the hinges.
