ASUS ZENFONE 3 Zoom Back Camera Replacement
  1. ASUS ZENFONE 3 Zoom Back Camera Replacement, Battery: step 1, image 1 of 2 ASUS ZENFONE 3 Zoom Back Camera Replacement, Battery: step 1, image 2 of 2
    Tool used on this step:
    Buy
    • Using a pair of tweezers, pull put the SIM card tray and set it to the side.
  2. ASUS ZENFONE 3 Zoom Back Camera Replacement: step 2, image 1 of 1
    • Remove the two 2 mm screws using a Torx T2 screwdriver.
  3. ASUS ZENFONE 3 Zoom Back Camera Replacement: step 3, image 1 of 2 ASUS ZENFONE 3 Zoom Back Camera Replacement: step 3, image 2 of 2
    • Insert a prying tool between the screen and the metal backing of the phone at the bottom to remove backing from phone.
    • There will be a thin film connecting the two pieces. You do not need to remove this. Just fold the two pieces apart with the inside facing up.
  4. ASUS ZENFONE 3 Zoom Back Camera Replacement: step 4, image 1 of 1
    • Remove the two 3 mm screws, using the Phillips #00 screwdriver, on the silver band at the top of the battery and remove the band.
  5. ASUS ZENFONE 3 Zoom Back Camera Replacement: step 5, image 1 of 1
    • Peel back the silver tape.
  6. ASUS ZENFONE 3 Zoom Back Camera Replacement: step 6, image 1 of 1
    • Disconnect the battery connections.
  7. ASUS ZENFONE 3 Zoom Back Camera Replacement: step 7, image 1 of 1
    • Pry and remove the battery.
    • The underside of the battery is adhesive so make sure to pry the battery off gently.
  8. ASUS ZENFONE 3 Zoom Back Camera Replacement, Back Camera: step 8, image 1 of 3 ASUS ZENFONE 3 Zoom Back Camera Replacement, Back Camera: step 8, image 2 of 3 ASUS ZENFONE 3 Zoom Back Camera Replacement, Back Camera: step 8, image 3 of 3
    • Remove the 3 mm screws, using the Phillips #00 screwdriver, from the black plastic piece at the top on the right side.
  9. ASUS ZENFONE 3 Zoom Back Camera Replacement: step 9, image 1 of 1
    • Remove the 3 mm screws, using the Phillips #00 screwdriver, from the metal piece around the camera.
  10. ASUS ZENFONE 3 Zoom Back Camera Replacement: step 10, image 1 of 2 ASUS ZENFONE 3 Zoom Back Camera Replacement: step 10, image 2 of 2
    • Remove the 3 mm circuit board screws, using the Phillips #00 screwdriver.
  11. ASUS ZENFONE 3 Zoom Back Camera Replacement: step 11, image 1 of 3 ASUS ZENFONE 3 Zoom Back Camera Replacement: step 11, image 2 of 3 ASUS ZENFONE 3 Zoom Back Camera Replacement: step 11, image 3 of 3
    • Unplug the two wires at the bottom of the circuit board.
  12. ASUS ZENFONE 3 Zoom Back Camera Replacement: step 12, image 1 of 1
    • Remove the circuit board.
  13. ASUS ZENFONE 3 Zoom Back Camera Replacement: step 13, image 1 of 2 ASUS ZENFONE 3 Zoom Back Camera Replacement: step 13, image 2 of 2
    • Unplug the camera.
2 Guide Comments
Excellent article. Just one question; who is selling this camera?
Hazem Tawfik - Reply
Very interesting images, my prob is , after replacing battery, camera just worked once a few minutes, then camera does not work again, why?
Philippe - Reply
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 15
All Time: 1,371
