ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement
  1. ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement, Back Cover: step 1, image 1 of 2 ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement, Back Cover: step 1, image 2 of 2
    • Flip the laptop over so the model stickers face the ceiling.
  2. ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement: step 2, image 1 of 2 ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement: step 2, image 2 of 2
    • Remove eleven 7mm Phillips #00 screws that secure the back cover.
    • Two screws are under the rubber pad.
  3. ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement: step 3, image 1 of 2 ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement: step 3, image 2 of 2
    • Using a spudger, carefully remove the back cover.
  4. ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement, Battery: step 4, image 1 of 2 ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement, Battery: step 4, image 2 of 2
    • Remove the six 3mm Phillips #00 screws holding the battery in place.
  5. ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement: step 5, image 1 of 2 ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement: step 5, image 2 of 2
    • Disconnect the battery wires from the motherboard by pulling on the black tab using a spudger or your hands.
  6. ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement: step 6, image 1 of 1
    • Carefully lift the battery up and out of the laptop.
  7. ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement, Hard Drive: step 7, image 1 of 3 ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement, Hard Drive: step 7, image 2 of 3 ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement, Hard Drive: step 7, image 3 of 3
    • Remove four 3 mm Phillips screws (two on each side) holding the hard drive in the frame
  8. ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement: step 8, image 1 of 2 ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement: step 8, image 2 of 2
    • Grip the side of the hard drive and slide it out of the device.
Joshua Letizia
193 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 580
