ASUS ZenBook UX302LA-BHI5T08 RAM Replacement
  1. ASUS ZenBook UX302LA-BHI5T08 RAM Replacement, Back Cover: step 1, image 1 of 2 ASUS ZenBook UX302LA-BHI5T08 RAM Replacement, Back Cover: step 1, image 2 of 2
    • Flip the laptop over so the model stickers face the ceiling.
  2. ASUS ZenBook UX302LA-BHI5T08 RAM Replacement: step 2, image 1 of 2 ASUS ZenBook UX302LA-BHI5T08 RAM Replacement: step 2, image 2 of 2
    • Remove eleven 7mm Phillips #00 screws that secure the back cover.
    • Two screws are under the rubber pad.
  3. ASUS ZenBook UX302LA-BHI5T08 RAM Replacement: step 3, image 1 of 2 ASUS ZenBook UX302LA-BHI5T08 RAM Replacement: step 3, image 2 of 2
    • Using a spudger, carefully remove the back cover.
  4. ASUS ZenBook UX302LA-BHI5T08 RAM Replacement, RAM: step 4, image 1 of 3 ASUS ZenBook UX302LA-BHI5T08 RAM Replacement, RAM: step 4, image 2 of 3 ASUS ZenBook UX302LA-BHI5T08 RAM Replacement, RAM: step 4, image 3 of 3
    • To unlock the RAM, simply move the metal brackets using your finger.
    • When the RAM is unlocked, it will elevate itself.
  5. ASUS ZenBook UX302LA-BHI5T08 RAM Replacement: step 5, image 1 of 2 ASUS ZenBook UX302LA-BHI5T08 RAM Replacement: step 5, image 2 of 2
    • Remove the RAM from the laptop.
  6. ASUS ZenBook UX302LA-BHI5T08 RAM Replacement: step 6, image 1 of 1
    • To insert the new RAM, line up the hole on the RAM stick and slot.
    • Next, push the RAM down gently. It should make a snap sound.
    • Do not use too much force as it can break the RAM.
Jin Feng Lin
330 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 471
