ASUS ZenBook UX302LA-BHI5T08 Solid State Drive Replacement
  1. ASUS ZenBook UX302LA-BHI5T08 Solid State Drive Replacement, Back Cover: step 1, image 1 of 2 ASUS ZenBook UX302LA-BHI5T08 Solid State Drive Replacement, Back Cover: step 1, image 2 of 2
    • Flip the laptop over so the model stickers face the ceiling.
  2. ASUS ZenBook UX302LA-BHI5T08 Solid State Drive Replacement: step 2, image 1 of 2 ASUS ZenBook UX302LA-BHI5T08 Solid State Drive Replacement: step 2, image 2 of 2
    • Remove eleven 7mm Phillips #00 screws that secure the back cover.
    • Two screws are under the rubber pad.
  3. ASUS ZenBook UX302LA-BHI5T08 Solid State Drive Replacement: step 3, image 1 of 2 ASUS ZenBook UX302LA-BHI5T08 Solid State Drive Replacement: step 3, image 2 of 2
    • Using a spudger, carefully remove the back cover.
  4. ASUS ZenBook UX302LA-BHI5T08 Solid State Drive Replacement, Battery: step 4, image 1 of 2 ASUS ZenBook UX302LA-BHI5T08 Solid State Drive Replacement, Battery: step 4, image 2 of 2
    • Remove the six 3mm Phillips #00 screws holding the battery in place.
  5. ASUS ZenBook UX302LA-BHI5T08 Solid State Drive Replacement: step 5, image 1 of 2 ASUS ZenBook UX302LA-BHI5T08 Solid State Drive Replacement: step 5, image 2 of 2
    • Disconnect the battery wires from the motherboard by pulling on the black tab using a spudger or your hands.
  6. ASUS ZenBook UX302LA-BHI5T08 Solid State Drive Replacement: step 6, image 1 of 1
    • Carefully lift the battery up and out of the laptop.
  7. ASUS ZenBook UX302LA-BHI5T08 Solid State Drive Replacement, Solid State Drive: step 7, image 1 of 2 ASUS ZenBook UX302LA-BHI5T08 Solid State Drive Replacement, Solid State Drive: step 7, image 2 of 2
    • Remove the two 3mm Phillips screws from the solid state drive.
    • The SSD will rotate upwards.
  8. ASUS ZenBook UX302LA-BHI5T08 Solid State Drive Replacement: step 8, image 1 of 2 ASUS ZenBook UX302LA-BHI5T08 Solid State Drive Replacement: step 8, image 2 of 2
    • Grip the SSD and pull gently away from the connection port to remove it.
Joshua Letizia
193 Reputation
2 Guides authored
One Comment
I’m curious… I just bought one of these, and after opening it up I only see 1 ram slot just like in your pictures. I can see I have 1 stick of 4gb installed, but task manager shows I’ve got 6gb installed soooo where’s the other RAM slot!? there’s another 2gb stick somewhere and I’d love to upgrade! Thanks!
Don Armstrong - Reply
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 6
All Time: 557
