ASUS ZenPad S 8.0 Motherboard Replacement
  1. ASUS ZenPad S 8.0 Motherboard Replacement, Rear Cover Removal: step 1, image 1 of 3 ASUS ZenPad S 8.0 Motherboard Replacement, Rear Cover Removal: step 1, image 2 of 3 ASUS ZenPad S 8.0 Motherboard Replacement, Rear Cover Removal: step 1, image 3 of 3
    • if present, remove the MicroSD card before disassembly. Failure to remove could lead to damage to the MicroSD card , rear cover, or MicroSD card slot.
    • Use the plastic tool to pry between the silver bezel and the back case
    • Work the tool around the device to free the back case
  2. ASUS ZenPad S 8.0 Motherboard Replacement: step 2, image 1 of 2 ASUS ZenPad S 8.0 Motherboard Replacement: step 2, image 2 of 2
    • Remove the ribbon cables by lifting up the white retaining flap on the ZIF connectors, then pulling the ribbon cable away.
    • Do not kink the ribbon cables as they can break easily
  3. ASUS ZenPad S 8.0 Motherboard Replacement: step 3, image 1 of 3 ASUS ZenPad S 8.0 Motherboard Replacement: step 3, image 2 of 3 ASUS ZenPad S 8.0 Motherboard Replacement: step 3, image 3 of 3
    • Remove the battery connector by prying it up away from the device using 2 plastic pry tools
  4. ASUS ZenPad S 8.0 Motherboard Replacement: step 4, image 1 of 2 ASUS ZenPad S 8.0 Motherboard Replacement: step 4, image 2 of 2
    • Remove all 9 of the 1.5mm #00 Philips screws
    • Gently lift the battery out of the device
    • Use an opening pick or similar tool to separate the adhesive on the bottom and top of the battery.
  5. ASUS ZenPad S 8.0 Motherboard Replacement, Front Facing Camera: step 5, image 1 of 3 ASUS ZenPad S 8.0 Motherboard Replacement, Front Facing Camera: step 5, image 2 of 3 ASUS ZenPad S 8.0 Motherboard Replacement, Front Facing Camera: step 5, image 3 of 3
    • Use a plastic opening tool to lift the black retaining flap on the ZIF Connector
  6. ASUS ZenPad S 8.0 Motherboard Replacement: step 6, image 1 of 1
    Tool used on this step:
    Buy
    • Use a tweezers to lift out the camera
    • If you lifted the latch for the ribbon cable then it should come out with little resistance.
  7. ASUS ZenPad S 8.0 Motherboard Replacement, Motherboard: step 7, image 1 of 2 ASUS ZenPad S 8.0 Motherboard Replacement, Motherboard: step 7, image 2 of 2
    • Using the plastic prying tool, lift the small retaining flap on the ZIF Connectors holding the ribbon cables to the motherboard
    • The removing of the ribbon cable is done in the same way as the front facing camera.
  8. ASUS ZenPad S 8.0 Motherboard Replacement: step 8, image 1 of 3 ASUS ZenPad S 8.0 Motherboard Replacement: step 8, image 2 of 3 ASUS ZenPad S 8.0 Motherboard Replacement: step 8, image 3 of 3
    Buy
    • Using the tweezers remove the connector gently from the yellow slot
    • Gently peel up the tape until is is completely released from the motherboard
  9. ASUS ZenPad S 8.0 Motherboard Replacement: step 9, image 1 of 2 ASUS ZenPad S 8.0 Motherboard Replacement: step 9, image 2 of 2
    • Cut the warranty tape connecting the motherboard to the metal plate under the battery
  10. ASUS ZenPad S 8.0 Motherboard Replacement: step 10, image 1 of 1
    • Using the #00 Phillips head screwdriver, remove the remaining 1.5mm screws in the motherboard
  11. ASUS ZenPad S 8.0 Motherboard Replacement: step 11, image 1 of 1
    • Gently lift the motherboard from your device
Jessica Voss
319 Reputation
1 Guide authored
USF Tampa, Team 2-2, Cagle Fall 2016 Member of USF Tampa, Team 2-2, Cagle Fall 2016
USFT-CAGLE-F16S2G2
4 Members
5 Guides authored
2 Comments
Where can I buy a spare motherboard for this device.
Partha Tripathy - Reply
Where are the motherboard sold and how do I purchase micro USB ports
Xibu Zhang - Reply
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 12
All Time: 2,638
