ASUS ZenWatch Battery Replacement
  1. ASUS ZenWatch Battery Replacement, Watch Strap Removal: step 1, image 1 of 2 ASUS ZenWatch Battery Replacement, Watch Strap Removal: step 1, image 2 of 2
    • On the strap there is a knob. Sliding this knob towards the opposite side of the strap releases the tension on the spring bar, allowing you to pull the strap out..
  2. ASUS ZenWatch Battery Replacement, Battery: step 2, image 1 of 3 ASUS ZenWatch Battery Replacement, Battery: step 2, image 2 of 3 ASUS ZenWatch Battery Replacement, Battery: step 2, image 3 of 3
    • Use the T5 Torx driver to remove the four screws on the case.
    • Use the magnetic pad to keep all your parts easily contained!
    • The case will pry easily off with just gentle hand pressure
  3. ASUS ZenWatch Battery Replacement: step 3, image 1 of 2 ASUS ZenWatch Battery Replacement: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • Using the tweezers, gently remove the fabric protecting the battery connection.
    • Take care when removing the fabric. Too much force may damage the contact with the metal tweezers.
    • Use the heavy duty spudger to gently push the contact towards the top of the case.
  4. ASUS ZenWatch Battery Replacement: step 4, image 1 of 3 ASUS ZenWatch Battery Replacement: step 4, image 2 of 3 ASUS ZenWatch Battery Replacement: step 4, image 3 of 3
    • Gently pry the battery up with the plastic pry tools
13 other people completed this guide.
Wayne McClure
961 Reputation
5 Guides authored
USF Tampa, Team 1-3, Sullivan Spring 2016 Member of USF Tampa, Team 1-3, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G3
4 Members
7 Guides authored
6 Guide Comments
Where could i find the modul replacement for asus zenwatch edition (1st editio) the chip body…thanks :) Dave
Davy Jones - Reply
Dónde puedo adquirir esta batería en Colombia
Jhon Jairo Piza Puerta - Reply
I want to find a battery for zenwatch 1 plz help i still have a fully functioning zenwatch I don’t want to waste it. (pref na or even better Canadian the shipping is murder)
wing_0_delta - Reply
Hi
im looking for a battery für Asus Viviwatch. Is ist the same as in ZenWatch?
mhoechtl - Reply
Looking to get zenwatch 1 battery. Any source recommended by anyone?
fine_pears - Reply
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 46
All Time: 14,637
