ASUS ZenWatch Charging Cradle Circuit board Replacement
  1. ASUS ZenWatch Charging Cradle Circuit board Replacement, Charging Cradle Circuit board: step 1, image 1 of 3 ASUS ZenWatch Charging Cradle Circuit board Replacement, Charging Cradle Circuit board: step 1, image 2 of 3 ASUS ZenWatch Charging Cradle Circuit board Replacement, Charging Cradle Circuit board: step 1, image 3 of 3
    • Using a metal spudger gently pry the plastic outer case apart
    • Pry open a little bit on each side before trying to open fully
  2. ASUS ZenWatch Charging Cradle Circuit board Replacement: step 2, image 1 of 3 ASUS ZenWatch Charging Cradle Circuit board Replacement: step 2, image 2 of 3 ASUS ZenWatch Charging Cradle Circuit board Replacement: step 2, image 3 of 3
    • Use the PH0 sized Phillips screwdriver to remove the three screws (2mm) holding the board to the cradle.
    • Gently pry up with your hands to pull the board off.
    • Don't grab directly on the USB port as you may loosen or bust the connections.
Wayne McClure
961 Reputation
5 Guides authored
USF Tampa, Team 1-3, Sullivan Spring 2016 Member of USF Tampa, Team 1-3, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G3
4 Members
7 Guides authored
One Comment
If you had listed what components were on the board or at least taken a picture of the other side of the board, I might have given you some points.
Nate Fansler - Reply
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 18
All Time: 2,881
