AT-LP60X Mechanical Reset
  1. AT-LP60X Mechanical Reset, Remove Power From The Turntable: step 1, image 1 of 1
    • Unplug the power source located on the back of the turntable.
  2. AT-LP60X Mechanical Reset, Press The Stop Button: step 2, image 1 of 1
    • Press the stop button located at the front of the turntable one time.
    • During this step, remove your record (if one is on the turntable) and remove the black felt mat.
  3. AT-LP60X Mechanical Reset, Perform Mechanical Reset: step 3, image 1 of 1
    • With your right hand, hold the tone arm in the rest so that it does not move.
    • With your left hand, slowly rotate the platter clockwise until you hear a series of clicks.
    • After hearing the series of clicks, the cam gear assembly should not rotate while the platter is spinning - if the cam gear is still rotating, press the stop button again and repeat Step 3.
    • Cam gear assembly - white gear visible through holes of the platter.
    • Allowing the tone arm to move freely during this process can result in the stylus being broken.
Finish Line
Anthony @ ATUS
1,195 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 71
Past 30 Days: 241
All Time: 1,501
