ATT CL2940 Handset Speaker Replacement
  1. ATT CL2940 Handset Speaker Replacement, Handset Speaker: step 1, image 1 of 2 ATT CL2940 Handset Speaker Replacement, Handset Speaker: step 1, image 2 of 2
    • Separate the two sections of the handset by pushing them apart with the tip of the metal spudger or opening tool.
  2. ATT CL2940 Handset Speaker Replacement: step 2, image 1 of 2 ATT CL2940 Handset Speaker Replacement: step 2, image 2 of 2
    • Continue separating the two sections by using the metal spudger all the way around the edge of the handset.
  3. ATT CL2940 Handset Speaker Replacement: step 3, image 1 of 1
    • After separating the two sections of the handset, it should look as shown.
  4. ATT CL2940 Handset Speaker Replacement: step 4, image 1 of 3 ATT CL2940 Handset Speaker Replacement: step 4, image 2 of 3 ATT CL2940 Handset Speaker Replacement: step 4, image 3 of 3
    • Pull the speaker out gently to detach it from the handset. The speaker is located at the top end of the handset. It is the circular white piece with red and greed wires connected to it.
    • The speaker is attached to the handset with a slightly sticky adhesive.
  5. ATT CL2940 Handset Speaker Replacement: step 5, image 1 of 2 ATT CL2940 Handset Speaker Replacement: step 5, image 2 of 2
    • Use a soldering iron to melt the existing solder off of both the red and green wires in order to completely remove the speaker.
Noor Assaf
306 Reputation
2 Guides authored
IUPUI, Team 1-1, Harley Spring 2016 Member of IUPUI, Team 1-1, Harley Spring 2016
IUPUI-HARLEY-S16S1G1
4 Members
13 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 14
All Time: 661
