ATT CL2940 Phone Jack Replacement
  1. ATT CL2940 Phone Jack Replacement, Back Panel: step 1, image 1 of 3 ATT CL2940 Phone Jack Replacement, Back Panel: step 1, image 2 of 3 ATT CL2940 Phone Jack Replacement, Back Panel: step 1, image 3 of 3
    • Remove five 9.5 mm Phillips #1 screws from the back panel of the phone.
  2. ATT CL2940 Phone Jack Replacement: step 2, image 1 of 3 ATT CL2940 Phone Jack Replacement: step 2, image 2 of 3 ATT CL2940 Phone Jack Replacement: step 2, image 3 of 3
    • Slide the metal spudger into the crack and continue around to the front panel of the phone.
    • Be careful not to break the clips that hold the back panel to the front panel.
  3. ATT CL2940 Phone Jack Replacement: step 3, image 1 of 1
    • When setting the back panel down, be careful to not rip any of the wires off of the internal components.
  4. ATT CL2940 Phone Jack Replacement, Phone Jack: step 4, image 1 of 2 ATT CL2940 Phone Jack Replacement, Phone Jack: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Using the precision tweezers, bend the golden tips of the green and red wires upward.
    • The wires are pulled out from two of the six holes. Make sure you remember which holes you pulled the wires out from.
    • Bend the wires slowly and gently to avoid breaking them.
  5. ATT CL2940 Phone Jack Replacement: step 5, image 1 of 3 ATT CL2940 Phone Jack Replacement: step 5, image 2 of 3 ATT CL2940 Phone Jack Replacement: step 5, image 3 of 3
    • After bending the golden wire tips, pull the wires out from the back side of the phone jack.
Noor Assaf
309 Reputation
2 Guides authored
IUPUI, Team 1-1, Harley Spring 2016 Member of IUPUI, Team 1-1, Harley Spring 2016
IUPUI-HARLEY-S16S1G1
4 Members
13 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 657
