ATT CL2940 Speakerphone Replacement
  1. ATT CL2940 Speakerphone Replacement, Back Panel: step 1, image 1 of 3 ATT CL2940 Speakerphone Replacement, Back Panel: step 1, image 2 of 3 ATT CL2940 Speakerphone Replacement, Back Panel: step 1, image 3 of 3
    • Remove five 9.5 mm Phillips #1 screws from the back panel of the phone.
  2. ATT CL2940 Speakerphone Replacement: step 2, image 1 of 3 ATT CL2940 Speakerphone Replacement: step 2, image 2 of 3 ATT CL2940 Speakerphone Replacement: step 2, image 3 of 3
    • Slide the metal spudger into the crack and continue around to the front panel of the phone.
    • Be careful not to break the clips that hold the back panel to the front panel.
  3. ATT CL2940 Speakerphone Replacement: step 3, image 1 of 1
    • When setting the back panel down, be careful to not rip any of the wires off of the internal components.
  4. ATT CL2940 Speakerphone Replacement, Speakerphone: step 4, image 1 of 2 ATT CL2940 Speakerphone Replacement, Speakerphone: step 4, image 2 of 2
    • Remove the front panel of the device as shown.
  5. ATT CL2940 Speakerphone Replacement: step 5, image 1 of 3 ATT CL2940 Speakerphone Replacement: step 5, image 2 of 3 ATT CL2940 Speakerphone Replacement: step 5, image 3 of 3
    • Desolder the speakerphone with a soldering iron.
    • If you are unfamiliar with solder, check out the article on soldering and be very careful. The iron is hot!
  6. ATT CL2940 Speakerphone Replacement: step 6, image 1 of 2 ATT CL2940 Speakerphone Replacement: step 6, image 2 of 2
    • Use the soldering iron to reconnect the wires to the new speaker.
    • Place the new speaker back in place.
    • Make sure that all of the components are back in place.
Finish Line
Charles Messmore
541 Reputation
5 Guides authored
IUPUI, Team 1-1, Harley Spring 2016 Member of IUPUI, Team 1-1, Harley Spring 2016
IUPUI-HARLEY-S16S1G1
4 Members
13 Guides authored
One Comment
Why do all these repairs require NO PARTS to replace defective parts?
And, of course< there is no links to a place to purchase the needed parts...
rpoland - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 616
