ATT CL4940 Internal Speaker Replacement
  1. ATT CL4940 Internal Speaker Replacement, Internal Speaker: step 1, image 1 of 2 ATT CL4940 Internal Speaker Replacement, Internal Speaker: step 1, image 2 of 2
    • Unplug your device before beginning disassembly.
    • Remove phone line and power cord from the back cover of the device.
    • Remove phone cable from the side of the device.
  2. ATT CL4940 Internal Speaker Replacement: step 2, image 1 of 1
    • Remove the five 4mm X 10mm Phillips head screws from the back cover of the device.
  3. ATT CL4940 Internal Speaker Replacement: step 3, image 1 of 3 ATT CL4940 Internal Speaker Replacement: step 3, image 2 of 3 ATT CL4940 Internal Speaker Replacement: step 3, image 3 of 3
    • Starting from the bottom of the device, use a metal spudger, separate the top (white) plastic piece from the bottom (gray) plastic piece.
    • Work your way across the bottom of the device, then to each side, and finally to the top.
    • There are brackets every few inches along the edge of the device. These may be difficult to pull apart.
    • The top and bottom pieces should separate, and the internals of the device will now be accessible.
  4. ATT CL4940 Internal Speaker Replacement: step 4, image 1 of 1
    • Using wire cutters, sever both the red and black wires connected to the speaker.
    • Carefully remove the speaker from the assembly.
    • Be sure to remove the rubber gasket from the broken speaker. You will need this for reassembly.
Charles Moore
201 Reputation
2 Guides authored
IUPUI, Team 2-2, Harley Spring 2016 Member of IUPUI, Team 2-2, Harley Spring 2016
IUPUI-HARLEY-S16S2G2
4 Members
8 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 11
All Time: 392
