ATT Trek HD 9020A Screen Replacement
  1. ATT Trek HD 9020A Screen Replacement, Back Cover: step 1, image 1 of 1
    • To separate the screen from the back panel, run the plastic opening tool along the outer edge of the device.
  2. ATT Trek HD 9020A Screen Replacement: step 2, image 1 of 1
    • Pull the screen away from the back panel.
  3. ATT Trek HD 9020A Screen Replacement, Battery: step 3, image 1 of 2 ATT Trek HD 9020A Screen Replacement, Battery: step 3, image 2 of 2
    • Use a Phillips #00 screwdriver to remove the six 2.5 mm screws located around the perimeter of the battery.
  4. ATT Trek HD 9020A Screen Replacement: step 4, image 1 of 2 ATT Trek HD 9020A Screen Replacement: step 4, image 2 of 2
    • Use the plastic opening tool to disconnect the black battery connector.
    • Gently lift the battery out of the device.
  5. ATT Trek HD 9020A Screen Replacement, Motherboard: step 5, image 1 of 2 ATT Trek HD 9020A Screen Replacement, Motherboard: step 5, image 2 of 2
    • Using a Phillips #00 screwdriver, remove the seven 1 mm screws on the green perimeter of the motherboard.
  6. ATT Trek HD 9020A Screen Replacement: step 6, image 1 of 2 ATT Trek HD 9020A Screen Replacement: step 6, image 2 of 2
    • Use the plastic opening tool to disconnect the large gold strip underneath the metal plate from the motherboard.
  7. ATT Trek HD 9020A Screen Replacement: step 7, image 1 of 1
    • Use the plastic opening tool to disconnect the front and back cameras from motherboard.
  8. ATT Trek HD 9020A Screen Replacement: step 8, image 1 of 2 ATT Trek HD 9020A Screen Replacement: step 8, image 2 of 2
    Tool used on this step:
    $3.99
    Buy
    • Use angled tweezers to pry up the black tab.
    • Use the angled tweezers to pull out the gold connector.
  9. ATT Trek HD 9020A Screen Replacement: step 9, image 1 of 2 ATT Trek HD 9020A Screen Replacement: step 9, image 2 of 2
    • Use the angled tweezers to disconnect the gold connector.
  10. ATT Trek HD 9020A Screen Replacement: step 10, image 1 of 1
    • Use the plastic opening tool to disconnect the black connectors on each side of the motherboard.
  11. ATT Trek HD 9020A Screen Replacement: step 11, image 1 of 2 ATT Trek HD 9020A Screen Replacement: step 11, image 2 of 2
    • Use the plastic opening tool to lift the motherboard out of place.
  12. ATT Trek HD 9020A Screen Replacement, Front Camera: step 12, image 1 of 2 ATT Trek HD 9020A Screen Replacement, Front Camera: step 12, image 2 of 2
    $3.99
    Buy
  13. ATT Trek HD 9020A Screen Replacement, Screen: step 13, image 1 of 3 ATT Trek HD 9020A Screen Replacement, Screen: step 13, image 2 of 3 ATT Trek HD 9020A Screen Replacement, Screen: step 13, image 3 of 3
    • Use the Phillips #00 screwdriver to remove the six 3 mm screws holding the black plastic corner pieces in place.
    • Gently lift the black corner pieces out of the device.
  14. ATT Trek HD 9020A Screen Replacement: step 14, image 1 of 2 ATT Trek HD 9020A Screen Replacement: step 14, image 2 of 2
    $3.99
    Buy
    • Use the angled tweezers to remove the black cables on each side of the device from their groove.
  15. ATT Trek HD 9020A Screen Replacement: step 15, image 1 of 2 ATT Trek HD 9020A Screen Replacement: step 15, image 2 of 2
    • Use the plastic opening tool to disconnect the black cable connectors from each side of the device.
  16. ATT Trek HD 9020A Screen Replacement: step 16, image 1 of 2 ATT Trek HD 9020A Screen Replacement: step 16, image 2 of 2
    • Remove the remaining ten 3 mm Phillips #00 screws.
  17. ATT Trek HD 9020A Screen Replacement: step 17, image 1 of 2 ATT Trek HD 9020A Screen Replacement: step 17, image 2 of 2
    • Use the plastic opening tool to disconnect the remaining three gold connectors at the bottom of the device.
  18. ATT Trek HD 9020A Screen Replacement: step 18, image 1 of 2 ATT Trek HD 9020A Screen Replacement: step 18, image 2 of 2
    • Use the plastic opening tool to pry up the grey plastic panel.
  19. ATT Trek HD 9020A Screen Replacement: step 19, image 1 of 2 ATT Trek HD 9020A Screen Replacement: step 19, image 2 of 2
    • Use the plastic opening tool to pry the screen out of the device.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 16
All Time: 809
