ATT Trek HD Battery Replacement
  1. ATT Trek HD Battery Replacement, Back Cover: step 1, image 1 of 1
    • To separate the screen from the back panel, run the plastic opening tool along the outer edge of the device.
  2. ATT Trek HD Battery Replacement: step 2, image 1 of 1
    • Pull the screen away from the back panel.
  3. ATT Trek HD Battery Replacement, Battery: step 3, image 1 of 2 ATT Trek HD Battery Replacement, Battery: step 3, image 2 of 2
    • Use a Phillips #00 screwdriver to remove the six 2.5 mm screws located around the perimeter of the battery.
  4. ATT Trek HD Battery Replacement: step 4, image 1 of 2 ATT Trek HD Battery Replacement: step 4, image 2 of 2
    • Use the plastic opening tool to disconnect the black battery connector.
    • Gently lift the battery out of the device.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 34
All Time: 1,379
