ATT Trimline 210M Motherboard Disassembly
  1. ATT Trimline 210M Motherboard Disassembly, ATT Trimline 210M Back Cover Disassembly: step 1, image 1 of 1
    • Open up the phone with a metal spudger, sticking it in the bottom near the cord jack entry.
    • Be careful with the amount of force you use, or the plastic may crack.
  2. ATT Trimline 210M Motherboard Disassembly: step 2, image 1 of 1
    • Pull up on the spudger while simultaneously pulling up the top shell of the phone.
  3. ATT Trimline 210M Motherboard Disassembly: step 3, image 1 of 1
    • After unclipping the bottom half of the shell, pull upward from the position shown in the picture to detach the top half of the shell.
    • The cord connecting the speaker is short, and may detach if not done carefully.
  4. ATT Trimline 210M Motherboard Disassembly: step 4, image 1 of 1
    • You will have the motherboard and speaker exposed to you.
  5. ATT Trimline 210M Motherboard Disassembly, ATT Trimline 210M Motherboard Disassembly: step 5, image 1 of 1
    • Remove the two 10 mm screws using the 1/4" driver and a J1 Phillips screw head.
  6. ATT Trimline 210M Motherboard Disassembly: step 6, image 1 of 1
    • Carefully move the motherboard up to remove it.
2 other people completed this guide.
Juan Carrillo
406 Reputation
3 Guides authored
USF Tampa, Team 4-2, Lacy Spring 2016 Member of USF Tampa, Team 4-2, Lacy Spring 2016
USFT-LACY-S16S4G2
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 930
