AYL SoundFit Battery Replacement
  1. AYL SoundFit Battery Replacement, Battery: step 1, image 1 of 1
    • Remove the four hex screws on the top of the device using a 2.5 hex screwdriver.
  2. AYL SoundFit Battery Replacement: step 2, image 1 of 1
    • Place a spudger between the black plastic cover and the green case.
    • Pry the black cover away from the main casing and remove the cover.
  3. AYL SoundFit Battery Replacement: step 3, image 1 of 1
    • Place a spudger between the black housing, which contains the woofer, and the outer rubber casing.
    • Pry the housing away from the body to reveal the motherboard, speaker, and battery.
  4. AYL SoundFit Battery Replacement: step 4, image 1 of 2 AYL SoundFit Battery Replacement: step 4, image 2 of 2
    • Remove the two Phillips #00 screws securing the battery casing.
    • Remove the battery case to reveal the battery.
  5. AYL SoundFit Battery Replacement: step 5, image 1 of 1
    • Desolder the positive and negative battery contacts from the motherboard.
    • Remove the battery from the device.
Dustin Moore
108 Reputation
1 Guide authored
IUPUI, Team 3-3, Harley Spring 2016 Member of IUPUI, Team 3-3, Harley Spring 2016
IUPUI-HARLEY-S16S3G3
4 Members
5 Guides authored
4 Guide Comments
Which battery is this, and what is the mAH?
jlongsa - Reply
3.7V 1500mAh, 5.55Wh
Coba Farr -
The charger works but it does not say chargeing
Zaira Cortes - Reply
18650 battery
rich4349 - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 3,056
