AYL SoundFit Motherboard Replacement
  1. AYL SoundFit Motherboard Replacement, Motherboard: step 1, image 1 of 1
    • Unscrew the four hex screws on the top of the device using a 2.5mm hex screwdriver.
  2. AYL SoundFit Motherboard Replacement: step 2, image 1 of 1
    • Place a spudger between the black plastic cover and the green case.
    • Remove the black cover away from the main casing and remove the cover.
  3. AYL SoundFit Motherboard Replacement: step 3, image 1 of 1
    • Place the spudger tool between the black housing, which contains the woofer, and the outer rubber casing.
    • Remove the housing away from the body to reveal the motherboard, speaker, and battery.
  4. AYL SoundFit Motherboard Replacement: step 4, image 1 of 2 AYL SoundFit Motherboard Replacement: step 4, image 2 of 2
    • Remove the two Phillips screws which hold its battery casing on the housing using a PH00 Phillips screwdriver.
    • Remove the battery case to reveal the battery.
  5. AYL SoundFit Motherboard Replacement: step 5, image 1 of 1
    • Using a soldering iron, heat up and remove both the positive and negative battery contacts from the motherboard.
  6. AYL SoundFit Motherboard Replacement: step 6, image 1 of 3 AYL SoundFit Motherboard Replacement: step 6, image 2 of 3 AYL SoundFit Motherboard Replacement: step 6, image 3 of 3
    • Remove all three Phillips screws which holds the motherboard to the base using a PH00 Phillips screwdriver.
    • The motherboard can now be wiggled free from the base.
3 other people completed this guide.
john
171 Reputation
1 Guide authored
IUPUI, Team 3-3, Harley Spring 2016 Member of IUPUI, Team 3-3, Harley Spring 2016
IUPUI-HARLEY-S16S3G3
4 Members
5 Guides authored
3 Guide Comments
Where do u get a new motherboard at?
calvinsmith522 - Reply
Anybody know where to get a motherboard?
David Whitman - Reply
Where do I get a motherboard?
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 29
All Time: 1,794
