Access to RAM and CPU from why! W253EU
  1. Access to RAM and CPU from why! W253EU, Battery from why! Remove W253EU: step 1, image 1 of 3 Access to RAM and CPU from why! W253EU, Battery from why! Remove W253EU: step 1, image 2 of 3 Access to RAM and CPU from why! W253EU, Battery from why! Remove W253EU: step 1, image 3 of 3
    • Turn off the computer.
    • Before each operation it is important to start with the removal of the accumulator.
    • Take the slide unlocked into position, remove the battery.
  2. Access to RAM and CPU from why! W253EU, Access to RAM and CPU from why! W253EU: step 2, image 1 of 2 Access to RAM and CPU from why! W253EU, Access to RAM and CPU from why! W253EU: step 2, image 2 of 2
    • Using a Philips #1 screwdriver, unscrew the 5 screws securing the cover.
  3. Access to RAM and CPU from why! W253EU: step 3, image 1 of 3 Access to RAM and CPU from why! W253EU: step 3, image 2 of 3 Access to RAM and CPU from why! W253EU: step 3, image 3 of 3
    • Push the screwdriver a few millimeters under the cover so that it can be touched with your fingers.
    • Now lift the cover carefully.
    • Attention! Disconnect the ventillator cable so that the cover can be completely removed (see next step).
  4. Access to RAM and CPU from why! W253EU: step 4, image 1 of 1
    • Since the ventillator is mounted under the cover, its power supply cable must first be disconnected so that the cover can then be completely removed.
For reassembly, follow the instructions in reverse order.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
31,100 Reputation
264 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 4
All Time: 275
