Accessing Logicboard
  1. Accessing Logicboard, Front and Back Cover: step 1, image 1 of 2 Accessing Logicboard, Front and Back Cover: step 1, image 2 of 2
    • Remove the following screws:
    • Two silver 3.15mm Phillips #00 screws on the right side of the camera
    • Two silver 2.08mm Phillips #00 screws on the left side of the camera
  2. Accessing Logicboard: step 2, image 1 of 1
    • Remove the two indicated screws on the bottom of the camera:
    • The screw circled in red is a longer silver 3.15mm Phillips #00 screw
    • The screw circled in blue is a shorter silver 2.25mm Phillips #00 screw
  3. Accessing Logicboard: step 3, image 1 of 2 Accessing Logicboard: step 3, image 2 of 2
    • Carefully pull the back of casing away from the front.
  4. Accessing Logicboard: step 4, image 1 of 3 Accessing Logicboard: step 4, image 2 of 3 Accessing Logicboard: step 4, image 3 of 3
    • After removing the back cover, several things must be removed.
    • Silver donut-shaped button will fall off. Place separately. Remove the plug covers on the right side of camera, labeled “PC/AV” and “DC IN 4.5V”.
  5. Accessing Logicboard: step 5, image 1 of 2 Accessing Logicboard: step 5, image 2 of 2
    • To remove the front cover, gently hold the inside structure of the camera and slowly pull the front cover off.
  6. Accessing Logicboard, Logicboard: step 6, image 1 of 2 Accessing Logicboard, Logicboard: step 6, image 2 of 2
    • On the front of the camera, in battery case, remove screws indicated:
    • Two black 2.05mm Phillips #00 screws
  7. Accessing Logicboard: step 7, image 1 of 2 Accessing Logicboard: step 7, image 2 of 2
    • Flip the camera over to the backside and remove screws indicated:
    • The screw circled in red is a longer black 3.00mm Phillips #00 screw
    • The screw circled in blue is a shorter black 2.00mm Phillips #00 screw
  8. Accessing Logicboard: step 8, image 1 of 1
    • Pull the cover plate off for the two power cord jacks.
  9. Accessing Logicboard: step 9, image 1 of 3 Accessing Logicboard: step 9, image 2 of 3 Accessing Logicboard: step 9, image 3 of 3
    • Cautiously and gently pull up the control board at the upper left corner, next to the viewfinder.
  10. Accessing Logicboard: step 10, image 1 of 1
    • Remove the orange tape on top of the SD cardholder.
  11. Accessing Logicboard: step 11, image 1 of 1
    • Open the battery cover.
  12. Accessing Logicboard: step 12, image 1 of 2 Accessing Logicboard: step 12, image 2 of 2
    • Lift the indicated plastic piece off.
  13. Accessing Logicboard: step 13, image 1 of 2 Accessing Logicboard: step 13, image 2 of 2
    • Remove screws indicated:
    • Two black 4.80mm Phillips #00 screws
  14. Accessing Logicboard: step 14, image 1 of 1
    • Unsolder points indicated.
    • Please refer to steps 1 through 6 of the Ifixit soldering guide to unsolder these leads.
  15. Accessing Logicboard: step 15, image 1 of 3 Accessing Logicboard: step 15, image 2 of 3 Accessing Logicboard: step 15, image 3 of 3
    • Carefully lift up SD cardholder to reveal logicboard.
Nicole Wong
350 Reputation
3 Guides authored
Cal Poly, Team 4-29, Regan Winter 2011 Member of Cal Poly, Team 4-29, Regan Winter 2011
CPSU-REGAN-W11S4G29
3 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 10
All Time: 1,620
