Introduction
The Accu2 is built around two 18650 Li-Ion batteries. When they wear with time and the lighting timing becomes too short, it's time to replace the batteries to get a new working Accu2.
Beware, the conception is very XXIth century compliant: you're not invited to get in. Despite this, with some patience and versatility you'll get it done.
Finally, an advisory foreword: you're going to manipulate a device with powerful Li-Ion batteries inside which have little or no limits to current intensity. This means that in case of a short, you may drain up to 30 A from one battery cell! This is enough to hurt you badly, so be careful!
Warning: Batteries can be dangerous. Exercise extreme caution when following this guide.
The top is maintained by four slotted screws... with a nice central tip!
To unscrew them, get an old slotted screwdriver in which you'll make a slot in the center of the blade (see picture 2).
Open the lid carefully, taking care not to damage the seal.
You can heat the cover a little with a hairdryer to soften the adhesive of the foam pads located between the motherboard inside the cover.
Unsolder the four connections of the batteries wires, marked C1+, C1-, C2+ and C2- on the board.
Be aware that they are soldered with a great amount of tin, you'll have to remove a good quantity of it. Beware not to heat too much the components around risking to unsolder them !
The P+ and P- wires aren't to be unsoldered. You can do this if you want though.
Lift up gently the main board from the opposite side of the wires to gain access to the two hax 6mm bolts that maintain the wires.
Using a hexagonal socket unscrew the two nuts. Be careful to recover the two split washers
The body is maintained in the housing by the two wires that connect to the lamp.
You'll have to unscrew them. Get the hex socket with its square only partially fitted in, so that the socket is long enough to unscrew.
Dont't unscrew totally, begin with only 4 to 5 millimeters (see picture 2)
Heat the bottom of the housing to soften the glue which is at the bottom of the batteries. You may use an hairdryer for 3 to five minutes to achieve that.
Now you can push on the wires, and pull on the bolts that you can have screwed back a little bit.
Take off gently the connecting strips along the batteries. You'll have to use some force to dismantle the electric soldering at the batteries ends. Try to keep the maximum length of the strings in order to facilitate the remounting process.
Mark the routing of the strings and the polarity of the batteries on the body (one with the + on top on on the bottom)
You can notice a small white box in the middle of the strings. It's a thermal protection with a switch inside that wxill open above 75°C.
On the way back, prepare your new batteries in soldering the wires on them (mind the position on the batteries). Get the thermal paste back in place to ensure good contact.
To reassemble follow the instructions in reverse order
- To rebuild the welding strip connection to the batteries, the best is electrical soldering. If you can only iron solder, be really careful not to heat the battery for a too long time.
- When inserting the batteries block into the housing, make sur it fits well and the connection strings and the thermal switch fit well and do not block.
- Before closing the top, make sure all the protection foams are in place and that the gasket is clean. Finally tighten the screw without exagaration, remember the force you applied unscrewing them.
4 other people completed this guide.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
12 Guide Comments
Could you do mine……. How much.
Hello, I possibly could, but I live in the south east of France… If you have to add the shipping costs it’s not a bargain and you’d better try it :-)
Otherwise if we can meet I would happily help you !
pichel -
Do you have the voltage and amperage of the charger? I'm planning to cut the wire in the side and add a IP68 connection to it (like a Bypass). So it'll be possible to connect another charger with the same properties, without destroying the proprietary connection.
Hello,
I've looked on the original charger, it says 8,4 V and 1A. 8,4 V is relevant for two Li batteries in serial, 1A is what the BMS needs for charging. If you can find a greater powered charger it's not a problem : the BMS will only takes what it needs and if your charger can deliver less than 1A it will still work, but in a greater timeframe though.
Is it possible to replace these cells by two Nitecore 3500 mAh?
