Acer AL1714 Video Display Board
  1. Acer AL1714 Video Display Board, Video Display Board: step 1, image 1 of 2 Acer AL1714 Video Display Board, Video Display Board: step 1, image 2 of 2
    • Turn the monitor face-down.
    • Unscrew the 5 screws holding back cover on.
    • (This may require flipping the monitor over and shaking the screws loose once they're already unscrewed)
  2. Acer AL1714 Video Display Board: step 2, image 1 of 3 Acer AL1714 Video Display Board: step 2, image 2 of 3 Acer AL1714 Video Display Board: step 2, image 3 of 3
    • Take the edge tool or a metal ruler and insert it into the bezel.
    • Apply pressure and push down.
    • Do the same to the right side.
    • Once the side of the bezel facing you is decoupled, take the back cover and pry it loose.
  3. Acer AL1714 Video Display Board: step 3, image 1 of 3 Acer AL1714 Video Display Board: step 3, image 2 of 3 Acer AL1714 Video Display Board: step 3, image 3 of 3
    • Remove the Flat Flex Cable from the Power Supply board located under the metal cage.
    • Pull the cord back and out of the way.
    • (It may be stuck down with adhesive)
  4. Acer AL1714 Video Display Board: step 4, image 1 of 3 Acer AL1714 Video Display Board: step 4, image 2 of 3 Acer AL1714 Video Display Board: step 4, image 3 of 3
    • Unscrew the cord anchors for the VGA port.
    • (Use needle nose pliers if they're too tight for removal by hand)
  5. Acer AL1714 Video Display Board: step 5, image 1 of 2 Acer AL1714 Video Display Board: step 5, image 2 of 2
    • Turn the monitor around.
    • Unscrew the 1 screw holding the Flat power Cable cover on.
    • Lift up and remove the Flat Power Cable cover.
    • (Careful: this may be sharp)
  6. Acer AL1714 Video Display Board: step 6, image 1 of 1
    • Unscrew the 5 screws holding the metal cage on.
  7. Acer AL1714 Video Display Board: step 7, image 1 of 2 Acer AL1714 Video Display Board: step 7, image 2 of 2
    • Lift the back of the metal cage slightly.
    • Pull the cage toward self.
    • (Must be careful to free the cover of the VGA port and the power supply input)
  8. Acer AL1714 Video Display Board: step 8, image 1 of 3 Acer AL1714 Video Display Board: step 8, image 2 of 3 Acer AL1714 Video Display Board: step 8, image 3 of 3
    • Lift the Flat Flex Cable holder tabs to release the cables.
    • Lift up on the Flat Flex Cables and bend them out of the working area.
  9. Acer AL1714 Video Display Board: step 9, image 1 of 3 Acer AL1714 Video Display Board: step 9, image 2 of 3 Acer AL1714 Video Display Board: step 9, image 3 of 3
    • Unplug the 4 backlight wires from their ports on the Power Supply Board.
    • (Considering their size, the best way to unplug the backlight wires is by slowly jiggling the wires out of place)
  10. Acer AL1714 Video Display Board: step 10, image 1 of 1
    • Unscrew the 5 screws holding the Power Supply and Video Display boards.
  11. Acer AL1714 Video Display Board: step 11, image 1 of 2 Acer AL1714 Video Display Board: step 11, image 2 of 2
    • Lift and remove the joined boards.
  12. Acer AL1714 Video Display Board: step 12, image 1 of 3 Acer AL1714 Video Display Board: step 12, image 2 of 3 Acer AL1714 Video Display Board: step 12, image 3 of 3
    • Carefully detach the two boards at their connector joint.
    • Replace outlined part.
2 other people completed this guide.
Christopher Kelly
590 Reputation
4 Guides authored
USF Tampa, Team 1-3, Brown Fall 2014 Member of USF Tampa, Team 1-3, Brown Fall 2014
USFT-BROWN-F14S1G3
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 16
All Time: 746
