Acer AL1916 Display Replacement
  1. Acer AL1916 Display Replacement, Stand: step 1, image 1 of 1
    • Lay the monitor on a flat surface so that the back is facing up.
  2. Acer AL1916 Display Replacement: step 2, image 1 of 2 Acer AL1916 Display Replacement: step 2, image 2 of 2
    • Grab the hinge cover with both hands on either side of the stand.
    • Squeeze inwards with your thumbs and fingers and lift up to remove the hinge cover.
  3. Acer AL1916 Display Replacement: step 3, image 1 of 2 Acer AL1916 Display Replacement: step 3, image 2 of 2
    • Remove the four 12.1 mm Phillips #2 screws that hold the stand to the monitor.
    • Support the monitor while removing the screws to prevent the monitor from falling.
    • Lift up to detach the stand.
  4. Acer AL1916 Display Replacement, Outer Case: step 4, image 1 of 2 Acer AL1916 Display Replacement, Outer Case: step 4, image 2 of 2
    • Remove the five 9.5 mm Phillips #2 screws located around the perimeter of the monitor.
  5. Acer AL1916 Display Replacement: step 5, image 1 of 3 Acer AL1916 Display Replacement: step 5, image 2 of 3 Acer AL1916 Display Replacement: step 5, image 3 of 3
    • Starting at the corner of the monitor, wedge the small plastic opening tool between the back cover and the display bezel.
    • Tilt the plastic opening tool up to separate the back cover from the display bezel.
    • Continue around the perimeter of the monitor until the display bezel comes off.
    • A reasonable amount of force is necessary to detach the back cover from the display bezel.
  6. Acer AL1916 Display Replacement: step 6, image 1 of 2 Acer AL1916 Display Replacement: step 6, image 2 of 2
    • Reposition the monitor so that the back is facing up.
    • Grab the corners of the monitor and jiggle them upwards to detach the back cover from the inside of the monitor.
    • Lift the back cover up.
  7. Acer AL1916 Display Replacement, EMI Shield: step 7, image 1 of 2 Acer AL1916 Display Replacement, EMI Shield: step 7, image 2 of 2
    • Remove the two 5.7 mm Phillips #2 screws located on either side of the EMI shield.
  8. Acer AL1916 Display Replacement: step 8, image 1 of 2 Acer AL1916 Display Replacement: step 8, image 2 of 2
    • Using a nut driver (or if necessary, needle-nose pliers), remove the two nuts on either side of the VGA input.
  9. Acer AL1916 Display Replacement: step 9, image 1 of 3 Acer AL1916 Display Replacement: step 9, image 2 of 3 Acer AL1916 Display Replacement: step 9, image 3 of 3
    • Grab the metal casing by the sides and slide it down towards the bottom of the monitor.
    • Lift up to remove the metal casing.
    • Beware, metal casing is sharp!
  10. Acer AL1916 Display Replacement, Display: step 10, image 1 of 2 Acer AL1916 Display Replacement, Display: step 10, image 2 of 2
    • Remove the three gold 7.5 mm Phillips #2 screws and one silver 8.3 mm Phillips #2 screw from the power supply.
  11. Acer AL1916 Display Replacement: step 11, image 1 of 3 Acer AL1916 Display Replacement: step 11, image 2 of 3 Acer AL1916 Display Replacement: step 11, image 3 of 3
    • Remove the two pieces of yellow tape on the left side of the power supply.
  12. Acer AL1916 Display Replacement: step 12, image 1 of 2 Acer AL1916 Display Replacement: step 12, image 2 of 2
    • Remove the four little white clips located underneath the pieces of tape by lifting up on their left side.
  13. Acer AL1916 Display Replacement: step 13, image 1 of 3 Acer AL1916 Display Replacement: step 13, image 2 of 3 Acer AL1916 Display Replacement: step 13, image 3 of 3
    • With the needle-nose pliers, remove the four display connectors by pulling directly left.
  14. Acer AL1916 Display Replacement: step 14, image 1 of 3 Acer AL1916 Display Replacement: step 14, image 2 of 3 Acer AL1916 Display Replacement: step 14, image 3 of 3
    • Remove the display cable located at the top of the circuit board by pulling it out towards the top of the monitor.
  15. Acer AL1916 Display Replacement: step 15, image 1 of 3 Acer AL1916 Display Replacement: step 15, image 2 of 3 Acer AL1916 Display Replacement: step 15, image 3 of 3
    • Turn the monitor on its side so that the power supply and circuit board are facing to the right
    • Remove the two 6.6 mm Phillips #2 screws located on both sides of the metal casing (four screws total).
  16. Acer AL1916 Display Replacement: step 16, image 1 of 2 Acer AL1916 Display Replacement: step 16, image 2 of 2
    • Set the monitor back down so that the power supply and circuit board are facing you.
    • Feed all four of the connector wires down through the metal casing.
  17. Acer AL1916 Display Replacement: step 17, image 1 of 3 Acer AL1916 Display Replacement: step 17, image 2 of 3 Acer AL1916 Display Replacement: step 17, image 3 of 3
    • Grab the sides of the metal casing and lift up.
    • Turn the display over to see the front; you are ready replace the broken display with a new one!
7 other people completed this guide.
Keith
375 Reputation
4 Guides authored
Cal Poly, Team 20-26, Maness Fall 2011 Member of Cal Poly, Team 20-26, Maness Fall 2011
CPSU-MANESS-F11S20G26
4 Members
14 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 71
All Time: 9,667
