Acer AL1916 Stand Replacement
  1. Acer AL1916 Stand Replacement, Stand: step 1, image 1 of 1
    • Lay the monitor on a flat surface so that the back is facing up.
  2. Acer AL1916 Stand Replacement: step 2, image 1 of 2 Acer AL1916 Stand Replacement: step 2, image 2 of 2
    • Grab the hinge cover with both hands on either side of the stand.
    • Squeeze inwards with your thumbs and fingers and lift up to remove the hinge cover.
  3. Acer AL1916 Stand Replacement: step 3, image 1 of 2 Acer AL1916 Stand Replacement: step 3, image 2 of 2
    • Remove the four 12.1 mm Phillips #2 screws that hold the stand to the monitor.
    • Support the monitor while removing the screws to prevent the monitor from falling.
    • Lift up to detach the stand.
8 other people completed this guide.
Keith
351 Reputation
4 Guides authored
Cal Poly, Team 20-26, Maness Fall 2011 Member of Cal Poly, Team 20-26, Maness Fall 2011
CPSU-MANESS-F11S20G26
4 Members
14 Guides authored
One Comment
Worked great…never would have guessed how to do it. Thanks.
GREG HILL - Reply
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 38
All Time: 20,248
