Acer Aspire 3 A315-21-92FX Speakers Replacement
  1. Acer Aspire 3 A315-21-92FX Speakers Replacement, RAM: step 1, image 1 of 1
    • Flip the Acer Aspire 3 A315-21-92FX over so the back-side is oriented to the upward position.
  2. Acer Aspire 3 A315-21-92FX Speakers Replacement: step 2, image 1 of 2 Acer Aspire 3 A315-21-92FX Speakers Replacement: step 2, image 2 of 2
    • Remove the single 2.5mm Phillips #0 screw.
  3. Acer Aspire 3 A315-21-92FX Speakers Replacement: step 3, image 1 of 1
    • Use the iFixit opening tool to remove the small cover.
  4. Acer Aspire 3 A315-21-92FX Speakers Replacement: step 4, image 1 of 3 Acer Aspire 3 A315-21-92FX Speakers Replacement: step 4, image 2 of 3 Acer Aspire 3 A315-21-92FX Speakers Replacement: step 4, image 3 of 3
    • Press the tabs on each side of the RAM outwards, and the memory module will pop up at an angle.
  5. Acer Aspire 3 A315-21-92FX Speakers Replacement: step 5, image 1 of 2 Acer Aspire 3 A315-21-92FX Speakers Replacement: step 5, image 2 of 2
    • Pull the RAM slowly out of the Acer Aspire 3 A315-21-92FX.
  6. Acer Aspire 3 A315-21-92FX Speakers Replacement, Hard Drive: step 6, image 1 of 1
    • Please make sure that there is no external access to the battery, and the battery is out of power.
    • Flip the Acer Aspire 3 A315-21-92FX over, so the back-side is oriented to the upward position.
  7. Acer Aspire 3 A315-21-92FX Speakers Replacement: step 7, image 1 of 2 Acer Aspire 3 A315-21-92FX Speakers Replacement: step 7, image 2 of 2
  8. Acer Aspire 3 A315-21-92FX Speakers Replacement: step 8, image 1 of 1
    • Use the iFixit opening tool to remove the cover of the hard disk.
  9. Acer Aspire 3 A315-21-92FX Speakers Replacement: step 9, image 1 of 2 Acer Aspire 3 A315-21-92FX Speakers Replacement: step 9, image 2 of 2
    • Pull the hard disk out of the Acer Aspire 3 A315-21-92FX slightly and slowly.
    • This laptop is missing the hard drive.
  10. Acer Aspire 3 A315-21-92FX Speakers Replacement, Battery: step 10, image 1 of 1
    • Remove fourteen 2.5mm Phillips #0 screws from the back of the laptop.
    • There may be two additional screws under the hard drive cover that must be removed before attempting to remove the back cover.
  11. Acer Aspire 3 A315-21-92FX Speakers Replacement: step 11, image 1 of 3 Acer Aspire 3 A315-21-92FX Speakers Replacement: step 11, image 2 of 3 Acer Aspire 3 A315-21-92FX Speakers Replacement: step 11, image 3 of 3
    • Use the iFixit opening tool to remove the back cover.
  12. Acer Aspire 3 A315-21-92FX Speakers Replacement: step 12, image 1 of 2 Acer Aspire 3 A315-21-92FX Speakers Replacement: step 12, image 2 of 2
    • Pull out the plug connecting the battery to the motherboard.
  13. Acer Aspire 3 A315-21-92FX Speakers Replacement: step 13, image 1 of 2 Acer Aspire 3 A315-21-92FX Speakers Replacement: step 13, image 2 of 2
    • Pull the battery out of the groove.
  14. Acer Aspire 3 A315-21-92FX Speakers Replacement, Speakers: step 14, image 1 of 1
    • Remove the speaker located in the right hand of the device first using the iFixit Opening Tool.
    • Place the edge of the iFixit Opening Tool under the speaker and pull it upward.
  15. Acer Aspire 3 A315-21-92FX Speakers Replacement: step 15, image 1 of 1
    • Remove the speaker from the left side of the computer using the iFixit Opening Tool.
  16. Acer Aspire 3 A315-21-92FX Speakers Replacement: step 16, image 1 of 2 Acer Aspire 3 A315-21-92FX Speakers Replacement: step 16, image 2 of 2
    • The cable that is connecting the speakers to the motherboard is placed under these plastic cables that are glued to the computer.
    • Remove these glued cables using the iFixit Opening Tool.
  17. Acer Aspire 3 A315-21-92FX Speakers Replacement: step 17, image 1 of 3 Acer Aspire 3 A315-21-92FX Speakers Replacement: step 17, image 2 of 3 Acer Aspire 3 A315-21-92FX Speakers Replacement: step 17, image 3 of 3
    • Detach the speaker connector from the motherboard with your fingers or the iFixit Opening Tool.
  18. Acer Aspire 3 A315-21-92FX Speakers Replacement: step 18, image 1 of 2 Acer Aspire 3 A315-21-92FX Speakers Replacement: step 18, image 2 of 2
    • Remove the speakers with your hands.
3 other people completed this guide.
gghhh
329 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 27
All Time: 1,497
