Acer Aspire 3 A315-24P-R7VH Display Assembly Replacement
  1. Acer Aspire 3 A315-24P-R7VH Display Assembly Replacement, Lower Case: step 1, image 1 of 1
    • Power off the machine and unplug it from the wall charger.
  2. Acer Aspire 3 A315-24P-R7VH Display Assembly Replacement: step 2, image 1 of 2 Acer Aspire 3 A315-24P-R7VH Display Assembly Replacement: step 2, image 2 of 2
    • Close the laptop and flip it over.
    • Remove the eleven 6.5 mm Phillips screws from the lower case.
  3. Acer Aspire 3 A315-24P-R7VH Display Assembly Replacement: step 3, image 1 of 1
    • Insert an opening pick between the lower case and chassis.
    • Pry around the entire perimeter until the lower case releases.
    • Remove the lower case.
  4. Acer Aspire 3 A315-24P-R7VH Display Assembly Replacement: step 4, image 1 of 1
    Tool used on this step:
    Anti-Static Wrist Strap
    $7.95
    Buy
    • Optional: Put on an anti-static wrist strap. Ground yourself by connecting the metal clip at the end to any unpainted metal surface outside of the laptop.
  5. Acer Aspire 3 A315-24P-R7VH Display Assembly Replacement, Display Assembly: step 5, image 1 of 3 Acer Aspire 3 A315-24P-R7VH Display Assembly Replacement, Display Assembly: step 5, image 2 of 3 Acer Aspire 3 A315-24P-R7VH Display Assembly Replacement, Display Assembly: step 5, image 3 of 3
    • Disconnect the black and white antenna cables plugged into the network card on the motherboard.
    • Unscrew the four 5.5 mm Phillips screws holding the hinges of the monitor to the laptop frame.
  6. Acer Aspire 3 A315-24P-R7VH Display Assembly Replacement: step 7, image 1 of 1
    • Once the hinges are unscrewed the display assembly will easily come off.
To reassemble you will just follow these steps in reverse order.
AlexHarpring
301 Reputation
3 Guides authored
Gateway, Team 1-1, Pee Fall 2023 Member of Gateway, Team 1-1, Pee Fall 2023
GCC-PEE-F23S1G1
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 44
All Time: 224
