Acer Aspire 3 A315-24P-R7VH Speaker Replacement
  1. Acer Aspire 3 A315-24P-R7VH Speaker Replacement, Lower Case: step 1, image 1 of 1
    • Power off the machine and unplug it from the wall charger.
  2. Acer Aspire 3 A315-24P-R7VH Speaker Replacement: step 2, image 1 of 2 Acer Aspire 3 A315-24P-R7VH Speaker Replacement: step 2, image 2 of 2
    • Close the laptop and flip it over.
    • Remove the eleven 6.5 mm Phillips screws from the lower case.
  3. Acer Aspire 3 A315-24P-R7VH Speaker Replacement: step 3, image 1 of 1
    • Insert an opening pick between the lower case and chassis.
    • Pry around the entire perimeter until the lower case releases.
    • Remove the lower case.
  4. Acer Aspire 3 A315-24P-R7VH Speaker Replacement: step 4, image 1 of 1
    Tool used on this step:
    Anti-Static Wrist Strap
    $7.95
    Buy
    • Optional: Put on an anti-static wrist strap. Ground yourself by connecting the metal clip at the end to any unpainted metal surface outside of the laptop.
  5. Acer Aspire 3 A315-24P-R7VH Speaker Replacement, Speaker: step 5, image 1 of 2 Acer Aspire 3 A315-24P-R7VH Speaker Replacement, Speaker: step 5, image 2 of 2
    • Find the speakers at the bottom left and right corners of the laptop.
  6. Acer Aspire 3 A315-24P-R7VH Speaker Replacement: step 6, image 1 of 1
    • Unplug each speaker carefully.
    • There are no screws holding the speakers in place, so once unplugged, lift them out.
  7. Acer Aspire 3 A315-24P-R7VH Speaker Replacement: step 7, image 1 of 2 Acer Aspire 3 A315-24P-R7VH Speaker Replacement: step 7, image 2 of 2
    • Plug in the new speaker and place it in the corner that correlates to its shape. The speaker that is to go to the left corner of the laptop will be labeled with an L, likewise the speaker for the right will be labeled with an R.
AlexHarpring
301 Reputation
3 Guides authored
Gateway, Team 1-1, Pee Fall 2023 Member of Gateway, Team 1-1, Pee Fall 2023
GCC-PEE-F23S1G1
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 17
All Time: 74
