Acer Aspire 3003WLCi Battery Replacement
  1. Acer Aspire 3003WLCi Battery Replacement, Battery: step 1, image 1 of 1
    • Turn the Acer Aspire 3003WLCi so that the bottom of the laptop is facing up. Orient it so that the battery is on your left.
  2. Acer Aspire 3003WLCi Battery Replacement: step 2, image 1 of 3 Acer Aspire 3003WLCi Battery Replacement: step 2, image 2 of 3 Acer Aspire 3003WLCi Battery Replacement: step 2, image 3 of 3
    • There will be two switches on the back of the laptop: one at the top of the battery, and one at the bottom.
    • Shift the bottom switch into an upward position in order to unlock the battery.
    • To unlock the upper switch, forcefully push the switch up and hold it in this position.
  3. Acer Aspire 3003WLCi Battery Replacement: step 3, image 1 of 2 Acer Aspire 3003WLCi Battery Replacement: step 3, image 2 of 2
    • While holding the upper switch in the upward position, remove the battery by pulling it out to the left.
    • You may need to be a bit forceful when pulling the battery to the left if it hasn't been removed before.
    • You have to maintain pulling the upper switch upwards, or the battery will not come out.
Tristin Viale
675 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 280
