Acer Aspire 4520-5464 Keyboard Replacement
  1. Acer Aspire 4520-5464 Keyboard Replacement, Battery: step 1, image 1 of 1
    • Shut down the computer and disconnect all external devices and cables.
    • Flip the computer over.
  2. Acer Aspire 4520-5464 Keyboard Replacement: step 2, image 1 of 2 Acer Aspire 4520-5464 Keyboard Replacement: step 2, image 2 of 2
    • Ensure that the battery compartment lock tab is in the unlocked position.
    • Slide the sliding black tab away from the battery compartment.
    • The inside edge of the battery should be released, causing it to slightly pop out of the compartment.
  3. Acer Aspire 4520-5464 Keyboard Replacement: step 3, image 1 of 1
    • Grasp the inside edge of the battery and lift to fully detach the battery from the computer.
  4. Acer Aspire 4520-5464 Keyboard Replacement, Keyboard: step 4, image 1 of 1
    • Remove the five 1mm Phillips #1 screws located inside of the battery compartment.
    • Remove the three 2mm Phillips #1 screws located at the top of the case's perimeter.
  5. Acer Aspire 4520-5464 Keyboard Replacement: step 5, image 1 of 2 Acer Aspire 4520-5464 Keyboard Replacement: step 5, image 2 of 2
    • Remove the gray plastic section located above the keyboard using the prying tool.
    • Lift off of the keyboard.
  6. Acer Aspire 4520-5464 Keyboard Replacement: step 6, image 1 of 2 Acer Aspire 4520-5464 Keyboard Replacement: step 6, image 2 of 2
    • Take hold of the keyboard behind the function keys and lift gently.
    • Do not completely separate the keyboard from the laptop.
  7. Acer Aspire 4520-5464 Keyboard Replacement: step 7, image 1 of 2 Acer Aspire 4520-5464 Keyboard Replacement: step 7, image 2 of 2
    • Lift up the black locking tab located where the keyboard is attached to the laptop.
    • Pull the keyboard cable towards the trackpad and remove the keyboard.
To reassemble your device, follow these instructions in reverse order using your new keyboard.
Hunter Gilcrease
367 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 25
All Time: 639
