Introduction
This guide will show you how to replace your old RAM..
The RAM is the main source of speed for your computer.
Replacing the RAM is an easy task with little risk of damaging critical components inside your computer.
Shut down the computer and disconnect all external devices and cables.
Flip the computer over.
Remove the seven 2mm Phillips #1 screws from the largest panel on back of the laptop.
Lift up the panel from the indent located on the right side.
