Acer Aspire 4741G-332G32Mn Motherboard Replacement
  1. Acer Aspire 4741G-332G32Mn Motherboard Replacement, Battery: step 1, image 1 of 1
    • Flip the lock latch to unlock battery.
  2. Acer Aspire 4741G-332G32Mn Motherboard Replacement: step 2, image 1 of 1
    • Slide the middle latch and remove the battery.
  3. Acer Aspire 4741G-332G32Mn Motherboard Replacement, Backplate: step 3, image 1 of 3 Acer Aspire 4741G-332G32Mn Motherboard Replacement, Backplate: step 3, image 2 of 3 Acer Aspire 4741G-332G32Mn Motherboard Replacement, Backplate: step 3, image 3 of 3
    • Pry off the keyboard using the opening tool.
    • Remove the two screws that are connected to the motherboard using a Phillips #0 screwdriver.
  4. Acer Aspire 4741G-332G32Mn Motherboard Replacement: step 4, image 1 of 1
    • Remove all 12 screws from the backplate using a Phillips #0 screwdriver.
  5. Acer Aspire 4741G-332G32Mn Motherboard Replacement: step 5, image 1 of 1
    • Using the prying tool to remove the bottom of the laptop.
  6. Acer Aspire 4741G-332G32Mn Motherboard Replacement, Fan: step 6, image 1 of 2 Acer Aspire 4741G-332G32Mn Motherboard Replacement, Fan: step 6, image 2 of 2
    • Using a Phillips #0 screwdriver, remove the eight screws that hold the motherboard to the frame of the laptop.
    • Disconnect the USB port from the motherboard.
  7. Acer Aspire 4741G-332G32Mn Motherboard Replacement: step 7, image 1 of 2 Acer Aspire 4741G-332G32Mn Motherboard Replacement: step 7, image 2 of 2
    • Unscrew the 6 screws that hold the fan to the motherboard using the same screwdriver.
  8. Acer Aspire 4741G-332G32Mn Motherboard Replacement, Motherboard: step 8, image 1 of 1
    • Remove the motherboard from the device.
Christopher Carstairs
256 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 16
All Time: 1,213
