Acer Aspire 4743-6481 DVD Drive Replacement
  1. Acer Aspire 4743-6481 DVD Drive Replacement, Battery: step 1, image 1 of 1
    • Turn over the laptop to view the underside.
  2. Acer Aspire 4743-6481 DVD Drive Replacement: step 2, image 1 of 1
    Tool used on this step:
    Buy
    • Use tweezers (or a similar tool) to slide the orange push pin. To release the battery, push it to the left.
  3. Acer Aspire 4743-6481 DVD Drive Replacement: step 3, image 1 of 1
    • You can lift the battery up and out now.
  4. Acer Aspire 4743-6481 DVD Drive Replacement, DVD Drive: step 4, image 1 of 1
    • Remove the 7.0 mm screw, circled in the picture, using a Phillips head screwdriver.
  5. Acer Aspire 4743-6481 DVD Drive Replacement: step 5, image 1 of 1
    • Once the screw is removed, the DVD drive should easily slide out
  6. Acer Aspire 4743-6481 DVD Drive Replacement: step 6, image 1 of 1
    • Remove the drive completely.
  7. Acer Aspire 4743-6481 DVD Drive Replacement: step 7, image 1 of 2 Acer Aspire 4743-6481 DVD Drive Replacement: step 7, image 2 of 2
    • Face the side of the DVD drive that connects to the laptop and remove the 3mm screw with a Phillips head screwdriver.
    • Put the screw and the bracket to the side as you may need it for your replacement.
2 other people completed this guide.
Filippo Santoro
279 Reputation
2 Guides authored
USF Tampa, Team S5-G1, Lacy Spring 2017 Member of USF Tampa, Team S5-G1, Lacy Spring 2017
USFT-LACY-S17S5G1
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 15
All Time: 742
