Acer Aspire 5 A515-46-R3UB RAM Replacement
  1. Acer Aspire 5 A515-46-R3UB RAM Replacement, Battery: step 1, image 1 of 2 Acer Aspire 5 A515-46-R3UB RAM Replacement, Battery: step 1, image 2 of 2
    • Use a JIS #1 screwdriver to remove eleven 6.7 mm screws from the bottom cover.
  2. Acer Aspire 5 A515-46-R3UB RAM Replacement: step 2, image 1 of 2 Acer Aspire 5 A515-46-R3UB RAM Replacement: step 2, image 2 of 2
    • Use an opening tool and picks to pry the bottom cover from the laptop.
    • Work your way around the perimeter to release any clips before you remove the bottom case.
    • Remove the bottom case.
  3. Acer Aspire 5 A515-46-R3UB RAM Replacement: step 3, image 1 of 2 Acer Aspire 5 A515-46-R3UB RAM Replacement: step 3, image 2 of 2
    • Remove the two pieces of tape from the battery and the battery connector.
    • Save the tape for reassembly.
  4. Acer Aspire 5 A515-46-R3UB RAM Replacement: step 4, image 1 of 2 Acer Aspire 5 A515-46-R3UB RAM Replacement: step 4, image 2 of 2
    • Use the plastic opening tool to carefully push on each side of the connector and remove it from the socket.
  5. Acer Aspire 5 A515-46-R3UB RAM Replacement: step 5, image 1 of 2 Acer Aspire 5 A515-46-R3UB RAM Replacement: step 5, image 2 of 2
    • Lift up the battery and remove it from the bottom case of the laptop.
  6. Acer Aspire 5 A515-46-R3UB RAM Replacement, RAM: step 6, image 1 of 2 Acer Aspire 5 A515-46-R3UB RAM Replacement, RAM: step 6, image 2 of 2
    • Insert upgraded RAM into the slot indicated in the photos.
0 Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 18
All Time: 366
