Acer Aspire 5 A515-46-R3UB Speakers Replacement
  1. Acer Aspire 5 A515-46-R3UB Speakers Replacement, Battery: step 1, image 1 of 2 Acer Aspire 5 A515-46-R3UB Speakers Replacement, Battery: step 1, image 2 of 2
    • Use a JIS #1 screwdriver to remove eleven 6.7 mm screws from the bottom cover.
  2. Acer Aspire 5 A515-46-R3UB Speakers Replacement: step 2, image 1 of 2 Acer Aspire 5 A515-46-R3UB Speakers Replacement: step 2, image 2 of 2
    • Use an opening tool and picks to pry the bottom cover from the laptop.
    • Work your way around the perimeter to release any clips before you remove the bottom case.
    • Remove the bottom case.
  3. Acer Aspire 5 A515-46-R3UB Speakers Replacement: step 3, image 1 of 2 Acer Aspire 5 A515-46-R3UB Speakers Replacement: step 3, image 2 of 2
    • Remove the two pieces of tape from the battery and the battery connector.
    • Save the tape for reassembly.
  4. Acer Aspire 5 A515-46-R3UB Speakers Replacement: step 4, image 1 of 2 Acer Aspire 5 A515-46-R3UB Speakers Replacement: step 4, image 2 of 2
    • Use the plastic opening tool to carefully push on each side of the connector and remove it from the socket.
  5. Acer Aspire 5 A515-46-R3UB Speakers Replacement: step 5, image 1 of 2 Acer Aspire 5 A515-46-R3UB Speakers Replacement: step 5, image 2 of 2
    • Lift up the battery and remove it from the bottom case of the laptop.
  6. Acer Aspire 5 A515-46-R3UB Speakers Replacement, Speakers: step 6, image 1 of 3 Acer Aspire 5 A515-46-R3UB Speakers Replacement, Speakers: step 6, image 2 of 3 Acer Aspire 5 A515-46-R3UB Speakers Replacement, Speakers: step 6, image 3 of 3
    • Lift the speakers off of the mounting pegs.
    • There is a speaker in the bottom left corner and bottom right corner.
  7. Acer Aspire 5 A515-46-R3UB Speakers Replacement: step 7, image 1 of 2 Acer Aspire 5 A515-46-R3UB Speakers Replacement: step 7, image 2 of 2
    • Undo the cables connecting both speakers from their routing hooks.
  8. Acer Aspire 5 A515-46-R3UB Speakers Replacement: step 8, image 1 of 3 Acer Aspire 5 A515-46-R3UB Speakers Replacement: step 8, image 2 of 3 Acer Aspire 5 A515-46-R3UB Speakers Replacement: step 8, image 3 of 3
    • Pull the speaker cable away from the connector in the same direction as the individual wires are running.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
    • To remove the cable from its mounting position, use a spudger to lift the ribbon cables off of the speaker cord.
    • Now that the speaker cable is released, remove the speakers.
2 other people completed this guide.
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 12
All Time: 251
