Acer Aspire 5100 Cooling Fan Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. Acer Aspire 5100 Cooling Fan Replacement, Battery: step 1, image 1 of 1
    • Make sure the laptop is turned off and unplugged.
    • Flip the laptop over so the audio jacks are facing you.
    • Unlock the battery by sliding the button (located above the battery) towards the outer edge of the computer. When you feel the battery release and pop up, gently pull the battery from its compartment.
  2. Acer Aspire 5100 Cooling Fan Replacement, Cooling Fan: step 2, image 1 of 1
    • Locate and remove the 5 screws that secure the panel over the RAM and CPU cover on the upper right hand side. These can be found in the center towards the corner opposite the battery compartment.
  3. Acer Aspire 5100 Cooling Fan Replacement: step 3, image 1 of 1
    • Lift up and remove the RAM and CPU cover.
  4. Acer Aspire 5100 Cooling Fan Replacement: step 4, image 1 of 1
    • Remove the two Phillips screws securing the fan.
    • Carefully disconnect the fan cable from the motherboard.
    • Lift up and remove the fan.
2 other people completed this guide.
iDeleted
2,101 Reputation
39 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 4,923
