Acer Aspire 5336-2524 Hard drive Replacement
  1. Acer Aspire 5336-2524 Hard drive Replacement, Battery: step 1, image 1 of 3 Acer Aspire 5336-2524 Hard drive Replacement, Battery: step 1, image 2 of 3 Acer Aspire 5336-2524 Hard drive Replacement, Battery: step 1, image 3 of 3
    • Flip over the laptop.
    • Make sure the battery lock is pushed down so the red part is exposed.
    • Push the switch all the way to the side and that will push the battery up.
    • Remove the battery.
  2. Acer Aspire 5336-2524 Hard drive Replacement, Hard drive: step 2, image 1 of 2 Acer Aspire 5336-2524 Hard drive Replacement, Hard drive: step 2, image 2 of 2
    • Remove the two M2.5x8 screws with a Phillips #0 screwdriver.
    • Use the plastic iFixit opening tool to pry open the lower door.
  3. Acer Aspire 5336-2524 Hard drive Replacement: step 3, image 1 of 3 Acer Aspire 5336-2524 Hard drive Replacement: step 3, image 2 of 3 Acer Aspire 5336-2524 Hard drive Replacement: step 3, image 3 of 3
    • Put slight pressure on the hard drive and slide it to the left.
    • Now pull the hard drive out.
  4. Acer Aspire 5336-2524 Hard drive Replacement: step 4, image 1 of 3 Acer Aspire 5336-2524 Hard drive Replacement: step 4, image 2 of 3 Acer Aspire 5336-2524 Hard drive Replacement: step 4, image 3 of 3
    • Remove both M2.5x8 screws on each side of the hard drive caddy, using a Phillips #0 screwdriver.
    • Lift the hard drive out of the caddy.
3 other people completed this guide.
Carlin Sullivan
695 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 12
All Time: 1,607
