Acer Aspire 5534-1146 Disc Drive Replacement
  1. Acer Aspire 5534-1146 Disc Drive  Replacement, Disc Drive: step 1, image 1 of 1
    • Unscrew the two .8 centimeter screws on the bottom plate with the PH #0 screwdriver.
  2. Acer Aspire 5534-1146 Disc Drive  Replacement: step 2, image 1 of 2 Acer Aspire 5534-1146 Disc Drive  Replacement: step 2, image 2 of 2
    • Using your fingers, or the blue plastic spudger tool if needed, remove the plate.
    • Then proceed to unscrew the .4 centimeter Phillips screw on the left side.
  3. Acer Aspire 5534-1146 Disc Drive  Replacement: step 3, image 1 of 2 Acer Aspire 5534-1146 Disc Drive  Replacement: step 3, image 2 of 2
    • You can now pull the disk drive out by hand.
  4. Acer Aspire 5534-1146 Disc Drive  Replacement: step 4, image 1 of 2 Acer Aspire 5534-1146 Disc Drive  Replacement: step 4, image 2 of 2
    • If needed, the small plate can be removed by unscrewing the two .4 centimeter Phillips screws.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 189
