Acer Aspire 5536 Display Replacement
  1. Acer Aspire 5536 Display Replacement, Display: step 1, image 1 of 1
    • Remove the 4 rubber supports from the screen. Then remove the screws underneath.
  2. Acer Aspire 5536 Display Replacement: step 2, image 1 of 2 Acer Aspire 5536 Display Replacement: step 2, image 2 of 2
    • With a spudger, release the clips that hold the plastic frame to the back cover.
    • Be careful while handling the bottom part, specially with the hinges, as there are cables inside.
  3. Acer Aspire 5536 Display Replacement: step 3, image 1 of 1
    • When all the clips are out, the entire plastic frame should come out easily.
  4. Acer Aspire 5536 Display Replacement: step 4, image 1 of 2 Acer Aspire 5536 Display Replacement: step 4, image 2 of 2
    • Carefully disconnect the camera cable.
  5. Acer Aspire 5536 Display Replacement: step 5, image 1 of 2 Acer Aspire 5536 Display Replacement: step 5, image 2 of 2
    • Remove the 4 screws located in the sides of the LCD screen.
  6. Acer Aspire 5536 Display Replacement: step 6, image 1 of 1
    • Remove the other 4 screws that secure the metal LCD frame to the hinges.
  7. Acer Aspire 5536 Display Replacement: step 7, image 1 of 3 Acer Aspire 5536 Display Replacement: step 7, image 2 of 3 Acer Aspire 5536 Display Replacement: step 7, image 3 of 3
    • Take the LCD screen out of the metal frame and flip it towards the keyboard.
  8. Acer Aspire 5536 Display Replacement: step 8, image 1 of 2 Acer Aspire 5536 Display Replacement: step 8, image 2 of 2
    • Remove the tape that holds the display cable.
    • Be careful not to take the entire tape away, as this may cause severe damage to the cable.
  9. Acer Aspire 5536 Display Replacement: step 9, image 1 of 2 Acer Aspire 5536 Display Replacement: step 9, image 2 of 2
    • Carefully disconnect the cable with a spuger.
  10. Acer Aspire 5536 Display Replacement: step 10, image 1 of 2 Acer Aspire 5536 Display Replacement: step 10, image 2 of 2
    • Unstick the cables from the back of the LCD screen.
    • The LCD should be completely free, so just take it out and install a new one.
8 other people completed this guide.
TechStem
461 Reputation
1 Guide authored
2 Guide Comments
Hi there.. I just bought a display for my aspire 5536 and it seems it has a different fitting for the cable.. in fact I bought an LED display and the original one was an LCD (there is an inverter fitted in the lid under the screen) ok.. my question.. Is that possible under any circumstances to fit this new LED screen in my laptop by changing the video cable with a proper one for this new screen??
Law199 - Reply Share
Hi, thanks for the info. Can you tell me the part number of the LCD screen? thanks.
Marcelo - Reply Share
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 39
All Time: 7,104
