Introduction
This guide will outline the removal and replacement of the RAM in an Acer Aspire 5740-5780 laptop. Replacement of RAM might be necessary if you are in need of more storage space on your laptop, or if it is running out of memory. Replacing the RAM in your laptop might also allow for your laptop to run faster, but it should be noted that this isn’t a permanent fix if your laptop is having performance issues.
Step 1 Prepare Acer Aspire 5740-5780 for Disassembly
Careful: steps 1-4 are sourced from a guide that's marked as in-progress.
Turn the laptop off and remove the power cord.
Put grounding strap on one of your wrists and attach the other end to a large metal object (recommended method).
If you don't have a grounding strap an alternative approach is to touch a metal object that is either large or connected to the earth. Then avoid doing things that would accumulate static electricity on your body.
Loosen the captive screw and remove the single M2.5 x L8 screw from the back panel using a Phillips #0 screwdriver.
