Acer Aspire 5750-6667 Memory Replacement
  1. Acer Aspire 5750-6667 Memory Replacement, Battery: step 1, image 1 of 2 Acer Aspire 5750-6667 Memory Replacement, Battery: step 1, image 2 of 2
    • Unplug the charging cable from the laptop and the wall. Failure to disconnect the charging cable could result in electric shock.
    • Turn the laptop over.
    • Locate the orange switch next to the battery.
  2. Acer Aspire 5750-6667 Memory Replacement: step 2, image 1 of 3 Acer Aspire 5750-6667 Memory Replacement: step 2, image 2 of 3 Acer Aspire 5750-6667 Memory Replacement: step 2, image 3 of 3
    Tool used on this step:
    Buy
    • Using a small tool such as tweezers or a pen, slide the orange switch completely to the left to unlock the battery.
    • While holding the orange switch in place, lift the battery by the lip and pull it away from the laptop.
  3. Acer Aspire 5750-6667 Memory Replacement, Bottom Access Panel: step 3, image 1 of 3 Acer Aspire 5750-6667 Memory Replacement, Bottom Access Panel: step 3, image 2 of 3 Acer Aspire 5750-6667 Memory Replacement, Bottom Access Panel: step 3, image 3 of 3
    • Flip the laptop over and locate the bottom access panel. It is opposite the battery.
    • Locate the 2 screws that hold the panel in place and unscrew them using a Phillips PH0 screwdriver.
  4. Acer Aspire 5750-6667 Memory Replacement: step 4, image 1 of 3 Acer Aspire 5750-6667 Memory Replacement: step 4, image 2 of 3 Acer Aspire 5750-6667 Memory Replacement: step 4, image 3 of 3
    • Use the blue plastic opening tool to lift the panel away from the laptop.
  5. Acer Aspire 5750-6667 Memory Replacement, RAM: step 5, image 1 of 3 Acer Aspire 5750-6667 Memory Replacement, RAM: step 5, image 2 of 3 Acer Aspire 5750-6667 Memory Replacement, RAM: step 5, image 3 of 3
    • Lift the clear plastic flap and locate the pair of metal brackets that are holding the top RAM in place.
    • Using your thumbs, push the brackets away from the RAM . It should pop up when released.
    • You can now gently pull the top RAM out of the laptop.
  6. Acer Aspire 5750-6667 Memory Replacement: step 6, image 1 of 3 Acer Aspire 5750-6667 Memory Replacement: step 6, image 2 of 3 Acer Aspire 5750-6667 Memory Replacement: step 6, image 3 of 3
    • Locate the second pair of metal clasps holding the bottom RAM in place.
    • Using your thumbs, push the brackets away from the RAM . The RAM board should pop up when released.
    • You can now gently pull the top RAM out of the laptop. Repeat for any other RAM boards that may be in the device.
2 other people completed this guide.
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 17
All Time: 886
