Acer Aspire 5750-6667 Optical Drive Replacement
  1. Acer Aspire 5750-6667 Optical Drive Replacement, Battery: step 1, image 1 of 2 Acer Aspire 5750-6667 Optical Drive Replacement, Battery: step 1, image 2 of 2
    • Unplug the charging cable from the laptop and the wall. Failure to disconnect the charging cable could result in electric shock.
    • Turn the laptop over.
    • Locate the orange switch next to the battery.
  2. Acer Aspire 5750-6667 Optical Drive Replacement: step 2, image 1 of 3 Acer Aspire 5750-6667 Optical Drive Replacement: step 2, image 2 of 3 Acer Aspire 5750-6667 Optical Drive Replacement: step 2, image 3 of 3
    Tool used on this step:
    Buy
    • Using a small tool such as tweezers or a pen, slide the orange switch completely to the left to unlock the battery.
    • While holding the orange switch in place, lift the battery by the lip and pull it away from the laptop.
  3. Acer Aspire 5750-6667 Optical Drive Replacement, Optical Drive: step 3, image 1 of 2 Acer Aspire 5750-6667 Optical Drive Replacement, Optical Drive: step 3, image 2 of 2
    • Locate the black screw just above the battery.
    • Remove the black screw holding the optical drive in place by using a Phillips #0 screwdriver.
  4. Acer Aspire 5750-6667 Optical Drive Replacement: step 4, image 1 of 2 Acer Aspire 5750-6667 Optical Drive Replacement: step 4, image 2 of 2
    • Pull the optical drive free from the laptop.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 1,291
