Acer Aspire 7736Z-4809 CPU Fan Replacement
  1. Acer Aspire 7736Z-4809 CPU Fan Replacement, Acer Aspire 7736Z-4809 Repair Preparation: step 1, image 1 of 1
    • Unplug and power off the laptop.
    • If the battery is still connected to the laptop, remove the battery.
  2. Acer Aspire 7736Z-4809 CPU Fan Replacement: step 2, image 1 of 1
    • Flip over the laptop so that the back panel of the laptop is facing up.
  3. Acer Aspire 7736Z-4809 CPU Fan Replacement, Back Panel: step 3, image 1 of 2 Acer Aspire 7736Z-4809 CPU Fan Replacement, Back Panel: step 3, image 2 of 2
    • Use the Phillips #1 screwdriver to remove the eight 6.5 mm Phillips #1 screws.
    • Only the four screws in the center are removable, the four along the edges are held in by rivets but can be loosened.
  4. Acer Aspire 7736Z-4809 CPU Fan Replacement: step 4, image 1 of 3 Acer Aspire 7736Z-4809 CPU Fan Replacement: step 4, image 2 of 3 Acer Aspire 7736Z-4809 CPU Fan Replacement: step 4, image 3 of 3
    • Remove the back panel of the laptop.
  5. Acer Aspire 7736Z-4809 CPU Fan Replacement: step 5, image 1 of 1
    • Connect a grounding cord to a metal interface on the laptop.
    • Ground the laptop to prevent static electricity from damaging the electrical components inside the laptop.
  6. Acer Aspire 7736Z-4809 CPU Fan Replacement, CPU Fan: step 6, image 1 of 3 Acer Aspire 7736Z-4809 CPU Fan Replacement, CPU Fan: step 6, image 2 of 3 Acer Aspire 7736Z-4809 CPU Fan Replacement, CPU Fan: step 6, image 3 of 3
    Tool used on this step:
    Buy
    • Use tweezers to remove the fan cable from its slot.
    • The cables consist of red, black, and yellow wires.
  7. Acer Aspire 7736Z-4809 CPU Fan Replacement: step 7, image 1 of 2 Acer Aspire 7736Z-4809 CPU Fan Replacement: step 7, image 2 of 2
    • Use the Phillips #1 screwdriver to unscrew the four Phillips #1 screws that connect the cooling fan from the panel.
    • These screws are held in the unit via springs. You cannot remove them. They can only be loosened.
  8. Acer Aspire 7736Z-4809 CPU Fan Replacement: step 8, image 1 of 3 Acer Aspire 7736Z-4809 CPU Fan Replacement: step 8, image 2 of 3 Acer Aspire 7736Z-4809 CPU Fan Replacement: step 8, image 3 of 3
    • Carefully remove the cooling fan from the motherboard.
    • Slightly lift up the fan, gradually slide it towards you and then fully remove it from the case.
  9. Acer Aspire 7736Z-4809 CPU Fan Replacement: step 9, image 1 of 1
    • Install the modified or new cooling fan.
2 other people completed this guide.
Pnithan Jantarakolica
1,153 Reputation
10 Guides authored
UC Davis, Team 2-4, Oliver Fall 2016 Member of UC Davis, Team 2-4, Oliver Fall 2016
UCD-OLIVER-F16S2G4
5 Members
10 Guides authored
One Comment
You’ll need some thermal compound when reinstalling for the heat syncs under the copper tube.
Minks - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 17
All Time: 814
