Acer Aspire 7736Z-4809 Wireless Module Replacement
  1. Acer Aspire 7736Z-4809 Wireless Module Replacement, Acer Aspire 7736Z-4809 Repair Preparation: step 1, image 1 of 1
    • Unplug and power off the laptop.
    • If the battery is still connected to the laptop, remove the battery.
  2. Acer Aspire 7736Z-4809 Wireless Module Replacement: step 2, image 1 of 1
    • Flip over the laptop so that the back panel of the laptop is facing up.
  3. Acer Aspire 7736Z-4809 Wireless Module Replacement, Back Panel: step 3, image 1 of 2 Acer Aspire 7736Z-4809 Wireless Module Replacement, Back Panel: step 3, image 2 of 2
    • Use the Phillips #1 screwdriver to remove the eight 6.5 mm Phillips #1 screws.
    • Only the four screws in the center are removable, the four along the edges are held in by rivets but can be loosened.
  4. Acer Aspire 7736Z-4809 Wireless Module Replacement: step 4, image 1 of 3 Acer Aspire 7736Z-4809 Wireless Module Replacement: step 4, image 2 of 3 Acer Aspire 7736Z-4809 Wireless Module Replacement: step 4, image 3 of 3
    • Remove the back panel of the laptop.
  5. Acer Aspire 7736Z-4809 Wireless Module Replacement: step 5, image 1 of 1
    • Connect a grounding cord to a metal interface on the laptop.
    • Ground the laptop to prevent static electricity from damaging the electrical components inside the laptop.
  6. Acer Aspire 7736Z-4809 Wireless Module Replacement, Wireless Module: step 6, image 1 of 3 Acer Aspire 7736Z-4809 Wireless Module Replacement, Wireless Module: step 6, image 2 of 3 Acer Aspire 7736Z-4809 Wireless Module Replacement, Wireless Module: step 6, image 3 of 3
    Tool used on this step:
    Buy
    • Remove the white antenna of the wireless module.
    • Use tweezers if you do not prefer using hands.
  7. Acer Aspire 7736Z-4809 Wireless Module Replacement: step 7, image 1 of 2 Acer Aspire 7736Z-4809 Wireless Module Replacement: step 7, image 2 of 2
    • Remove the black antenna of the wireless module.
  8. Acer Aspire 7736Z-4809 Wireless Module Replacement: step 8, image 1 of 3 Acer Aspire 7736Z-4809 Wireless Module Replacement: step 8, image 2 of 3 Acer Aspire 7736Z-4809 Wireless Module Replacement: step 8, image 3 of 3
    • Use the Phillips #1 screwdriver to remove the two 4.8mm Phillips #1 screws.
  9. Acer Aspire 7736Z-4809 Wireless Module Replacement: step 9, image 1 of 2 Acer Aspire 7736Z-4809 Wireless Module Replacement: step 9, image 2 of 2
    • Remove the wireless module from the laptop.
Pnithan Jantarakolica
1,153 Reputation
10 Guides authored
UC Davis, Team 2-4, Oliver Fall 2016 Member of UC Davis, Team 2-4, Oliver Fall 2016
UCD-OLIVER-F16S2G4
5 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 22
All Time: 384
