Acer Aspire 7741Z-4643 RAMReplacement
  1. Acer Aspire 7741Z-4643 RAMReplacement, RAM: step 1, image 1 of 3 Acer Aspire 7741Z-4643 RAMReplacement, RAM: step 1, image 2 of 3 Acer Aspire 7741Z-4643 RAMReplacement, RAM: step 1, image 3 of 3
    • Begin with the bottom of the laptop facing up.
    • With a screwdriver, unscrew the four phillips #0 7.5mm screw around the bottom panel.
    • Lift the panel at the top and pull towards you to remove it from the laptop.
  2. Acer Aspire 7741Z-4643 RAMReplacement: step 2, image 1 of 3 Acer Aspire 7741Z-4643 RAMReplacement: step 2, image 2 of 3 Acer Aspire 7741Z-4643 RAMReplacement: step 2, image 3 of 3
    • The memory should be to the right, after you have removed the bottom panel.
    • Towards the bottom of the memory card, push outwards on the two small silver levers to release the memory card.
    • Pull the memory card out towards you to remove it.
Amy Endo
186 Reputation
1 Guide authored
UC Davis, Team S11-G4, Lore Fall 2018 Member of UC Davis, Team S11-G4, Lore Fall 2018
UCD-LORE-F18S11G4
4 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 17
All Time: 489
