Acer Aspire E 11 Motherboard Replacement
  1. Acer Aspire E 11 Motherboard Replacement, Lower Case: step 1, image 1 of 2 Acer Aspire E 11 Motherboard Replacement, Lower Case: step 1, image 2 of 2
    • Unscrew the thirteen 6.2mm Phillips #1 screws located on the bottom of the device.
  2. Acer Aspire E 11 Motherboard Replacement: step 2, image 1 of 3 Acer Aspire E 11 Motherboard Replacement: step 2, image 2 of 3 Acer Aspire E 11 Motherboard Replacement: step 2, image 3 of 3
    • Lift the back panel using a plastic opening tool. Slowly make your way around the device until the back panel comes off.
  3. Acer Aspire E 11 Motherboard Replacement, Battery: step 3, image 1 of 2 Acer Aspire E 11 Motherboard Replacement, Battery: step 3, image 2 of 2
    • Press and hold the small black button located on the motherboard just above the battery for five seconds.
  4. Acer Aspire E 11 Motherboard Replacement: step 4, image 1 of 3 Acer Aspire E 11 Motherboard Replacement: step 4, image 2 of 3 Acer Aspire E 11 Motherboard Replacement: step 4, image 3 of 3
    • Using two plastic opening tools tightly grab the connector going from the battery to the motherboard and pull to unplug.
  5. Acer Aspire E 11 Motherboard Replacement: step 5, image 1 of 3 Acer Aspire E 11 Motherboard Replacement: step 5, image 2 of 3 Acer Aspire E 11 Motherboard Replacement: step 5, image 3 of 3
    • Unscrew two 6.2 mm Phillips #1 screws on the right and left sides of the battery.
  6. Acer Aspire E 11 Motherboard Replacement: step 6, image 1 of 1
    • Carefully remove the battery by lifting it out of the casing.
  7. Acer Aspire E 11 Motherboard Replacement, Motherboard: step 7, image 1 of 3 Acer Aspire E 11 Motherboard Replacement, Motherboard: step 7, image 2 of 3 Acer Aspire E 11 Motherboard Replacement, Motherboard: step 7, image 3 of 3
    • Locate the keyboard cable on the motherboard. Using, two plastic opening tools on each side of the connector, pull the two gray tabs outward and then remove the cable from the motherboard.
  8. Acer Aspire E 11 Motherboard Replacement: step 8, image 1 of 3 Acer Aspire E 11 Motherboard Replacement: step 8, image 2 of 3 Acer Aspire E 11 Motherboard Replacement: step 8, image 3 of 3
    • Use a plastic opening tool to carefully lift the white hinge up on the touchpad cable connector, and gently remove the cable from the motherboard.
  9. Acer Aspire E 11 Motherboard Replacement: step 9, image 1 of 3 Acer Aspire E 11 Motherboard Replacement: step 9, image 2 of 3 Acer Aspire E 11 Motherboard Replacement: step 9, image 3 of 3
    • Use two plastic opening tools to grip each side of the connector for the speaker cable and gently pull the cable from the motherboard.
  10. Acer Aspire E 11 Motherboard Replacement: step 10, image 1 of 3 Acer Aspire E 11 Motherboard Replacement: step 10, image 2 of 3 Acer Aspire E 11 Motherboard Replacement: step 10, image 3 of 3
    • Remove the tape on the connector for the display cable.
    • Use two plastic opening tools to grip each side of the connector and gently pull the display cable from the motherboard.
  11. Acer Aspire E 11 Motherboard Replacement: step 11, image 1 of 2 Acer Aspire E 11 Motherboard Replacement: step 11, image 2 of 2
    • Remove one 6.2 mm Phillips #1 screw from the wireless chip on the left side of the motherboard.
  12. Acer Aspire E 11 Motherboard Replacement: step 12, image 1 of 3 Acer Aspire E 11 Motherboard Replacement: step 12, image 2 of 3 Acer Aspire E 11 Motherboard Replacement: step 12, image 3 of 3
    • Remove three 6.2 mm Phillips #1 screws that attach the motherboard to the laptop casing.
  13. Acer Aspire E 11 Motherboard Replacement: step 13, image 1 of 1
    • Return to the wireless chip and gently pull it from the connector on the side of the motherboard.
  14. Acer Aspire E 11 Motherboard Replacement: step 14, image 1 of 1
    • The motherboard can now be lifted out from the laptop casing.
3 other people completed this guide.
Carlos Rodriguez
435 Reputation
2 Guides authored
USF Tampa, Team 16-1, Blackwell Winter 2016 Member of USF Tampa, Team 16-1, Blackwell Winter 2016
USFT-BLACKWELL-W16S16G1
4 Members
11 Guides authored
3 Comments
Some of the bullet points can be broken up into information points or divided into more bullet points per step. Also, make sure the exposure is high enough to make all parts visible
Jaie Hillery - Reply
Hello, What is WiFi+BT card model ? Is it Atheros?
Da K - Reply
Me podrĂ­an decir cual es el modelo de la pila del BIOS de este modelo e11 , por favor
Jesus Quiroz - Reply
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 20
All Time: 5,336
