Acer Aspire E 11 Touchpad Replacement
  1. Acer Aspire E 11 Touchpad Replacement, Lower Case: step 1, image 1 of 2 Acer Aspire E 11 Touchpad Replacement, Lower Case: step 1, image 2 of 2
    • Unscrew the thirteen 6.2mm Phillips #1 screws located on the bottom of the device.
  2. Acer Aspire E 11 Touchpad Replacement: step 2, image 1 of 3 Acer Aspire E 11 Touchpad Replacement: step 2, image 2 of 3 Acer Aspire E 11 Touchpad Replacement: step 2, image 3 of 3
    • Lift the back panel using a plastic opening tool. Slowly make your way around the device until the back panel comes off.
  3. Acer Aspire E 11 Touchpad Replacement, Battery: step 3, image 1 of 2 Acer Aspire E 11 Touchpad Replacement, Battery: step 3, image 2 of 2
    • Press and hold the small black button located on the motherboard just above the battery for five seconds.
  4. Acer Aspire E 11 Touchpad Replacement: step 4, image 1 of 3 Acer Aspire E 11 Touchpad Replacement: step 4, image 2 of 3 Acer Aspire E 11 Touchpad Replacement: step 4, image 3 of 3
    • Using two plastic opening tools tightly grab the connector going from the battery to the motherboard and pull to unplug.
  5. Acer Aspire E 11 Touchpad Replacement: step 5, image 1 of 3 Acer Aspire E 11 Touchpad Replacement: step 5, image 2 of 3 Acer Aspire E 11 Touchpad Replacement: step 5, image 3 of 3
    • Unscrew two 6.2 mm Phillips #1 screws on the right and left sides of the battery.
  6. Acer Aspire E 11 Touchpad Replacement: step 6, image 1 of 1
    • Carefully remove the battery by lifting it out of the casing.
  7. Acer Aspire E 11 Touchpad Replacement, Motherboard: step 7, image 1 of 3 Acer Aspire E 11 Touchpad Replacement, Motherboard: step 7, image 2 of 3 Acer Aspire E 11 Touchpad Replacement, Motherboard: step 7, image 3 of 3
    • Locate the keyboard cable on the motherboard. Using, two plastic opening tools on each side of the connector, pull the two gray tabs outward and then remove the cable from the motherboard.
  8. Acer Aspire E 11 Touchpad Replacement: step 8, image 1 of 3 Acer Aspire E 11 Touchpad Replacement: step 8, image 2 of 3 Acer Aspire E 11 Touchpad Replacement: step 8, image 3 of 3
    • Use a plastic opening tool to carefully lift the white hinge up on the touchpad cable connector, and gently remove the cable from the motherboard.
  9. Acer Aspire E 11 Touchpad Replacement: step 9, image 1 of 3 Acer Aspire E 11 Touchpad Replacement: step 9, image 2 of 3 Acer Aspire E 11 Touchpad Replacement: step 9, image 3 of 3
    • Use two plastic opening tools to grip each side of the connector for the speaker cable and gently pull the cable from the motherboard.
  10. Acer Aspire E 11 Touchpad Replacement: step 10, image 1 of 3 Acer Aspire E 11 Touchpad Replacement: step 10, image 2 of 3 Acer Aspire E 11 Touchpad Replacement: step 10, image 3 of 3
    • Remove the tape on the connector for the display cable.
    • Use two plastic opening tools to grip each side of the connector and gently pull the display cable from the motherboard.
  11. Acer Aspire E 11 Touchpad Replacement: step 11, image 1 of 2 Acer Aspire E 11 Touchpad Replacement: step 11, image 2 of 2
    • Remove one 6.2 mm Phillips #1 screw from the wireless chip on the left side of the motherboard.
  12. Acer Aspire E 11 Touchpad Replacement: step 12, image 1 of 3 Acer Aspire E 11 Touchpad Replacement: step 12, image 2 of 3 Acer Aspire E 11 Touchpad Replacement: step 12, image 3 of 3
    • Remove three 6.2 mm Phillips #1 screws that attach the motherboard to the laptop casing.
  13. Acer Aspire E 11 Touchpad Replacement: step 13, image 1 of 1
    • Return to the wireless chip and gently pull it from the connector on the side of the motherboard.
  14. Acer Aspire E 11 Touchpad Replacement: step 14, image 1 of 1
    • The motherboard can now be lifted out from the laptop casing.
  15. Acer Aspire E 11 Touchpad Replacement, Touchpad: step 15, image 1 of 2 Acer Aspire E 11 Touchpad Replacement, Touchpad: step 15, image 2 of 2
    • Start by peeling off the touchpad cable that is stuck to the computer.
  16. Acer Aspire E 11 Touchpad Replacement: step 16, image 1 of 2 Acer Aspire E 11 Touchpad Replacement: step 16, image 2 of 2
    • Peel back the silver tape revealing two 6.2 mm Phillips #1 black screws.
    • Remove the three 6.2 mm Phillips # 1 black screws.
  17. Acer Aspire E 11 Touchpad Replacement: step 17, image 1 of 3 Acer Aspire E 11 Touchpad Replacement: step 17, image 2 of 3 Acer Aspire E 11 Touchpad Replacement: step 17, image 3 of 3
    • Once unscrewed, use the plastic opening tools to lift and slide out the touchpad. Be careful not to damage the speaker wire that runs across it when removing.
2 other people completed this guide.
Stephen Robinson
164 Reputation
1 Guide authored
USF Tampa, Team 16-1, Blackwell Winter 2016 Member of USF Tampa, Team 16-1, Blackwell Winter 2016
USFT-BLACKWELL-W16S16G1
4 Members
11 Guides authored
One Comment
Some of the bullet points can be broken up into information points or divided into more bullet points per step. Also, make sure that the exposure is high enough so that some of the images are brighter and visible.
Jaie Hillery - Reply
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 26
All Time: 3,412
